Datasheet HRS4-S-DC12V - Multicomp Даташит Реле, PCB, SPCO, 12DC — Даташит
Multicomp HRS4-S-DC12V
Наименование модели: HRS4-S-DC12V
Реле Мощности, RELAY, PCB, SPCO, 12DC; Series: HRS4; Relay Type: Power; Voltage, Coil DC Nom: 12V; Resistance, Coil: 320Ω; Poles, ......
HRS4-S-DC12V
Multicomp
111 ₽
Элитан
HRS4-S-DC12V
Multicomp
175 ₽
727GS
HRS4-S-DC12V
Multicomp
HRS4-S-DC12V
Multicomp
Производитель: Multicomp
Описание: Реле, PCB, SPCO, 12DC
data sheetСкачать Data Sheet
HRS4 Series PCB Power Relays
Features:
· SPCO contacts.
· Sealed to allow washing after flow soldering.
Specifications:
Coil Data: Nominal Voltage Nominal Power Consumption Contact Data: Contact Arrangement Contact Material Contact Rating Maximum Switching Voltage Maximum Switching Current Maximum Switching Power Contact Resistance (Initial) Life Expectancy Electrical Mechanical General Data: Minimum Insulation Resistance Dielectric Strength Maximum Operate Time Maximum Release Time Operating Temperature Range Shock Resistance Vibration Resistance : 100M at 500V dc. : 750V ac, 1 minute between open contacts 1,500V ac, 1 minute between contacts and coil. : 8ms. : 5ms. : -30°C to +85°C. : 10G. : 10 - 55Hz , Amplitude 1.5mm. : 1 Form A , 1 Form C. : AgCdo. : 10A 120V ac/24V dc (1C). 15A 120V ac/24V dc (1A). : 110V dc/240V ac. : 15A. : 1800VA , 360W. : 50m at 6V dc 1A. : 100,000 operations at nominal load : 10,000,000 operations. : 3V dc to 48V dc. : 360 to 450 mW.
  • Тип реле: Power
  • Coil Voltage VDC Nom: 12 В
  • Contact Current Max: 15 А
  • Contact Voltage AC Nom: 120 В
  • Contact Voltage DC Nom: 24 В
  • Coil Resistance: 320 Ом
  • Contact Configuration: SPCO
  • Coil Type: DC Coil
  • Nom Operating Power: 450 мВт
  • Relay Mounting: PC Board
  • Внешняя длина / высота: 15.8 мм
  • Внешняя ширина: 15.5 мм
  • External Depth: 19 мм
  • Contact Current AC Max: 5 А
  • Contact Current DC Max: 5 А
  • Contact Voltage AC Max: 240 В
  • Contact Voltage DC Max: 24 В
  • Mounting Type: PCB
  • Number of Poles: 1
  • Семейство: HRS4
  • Approval Bodies: UL
  • DC Coil Power: 720 мВт
  • Operating Time: 8 мс
  • Release Time: 5 мс
  • Switch Current Max: 15 А
  • Рабочий диапазон температрур: -30°C ... 70°C
HRS4SDC12V, HRS4 S DC12V
На английском языке: Datasheet HRS4-S-DC12V - Multicomp RELAY, PCB, SPCO, 12DC
