Datasheet R04-11D30-24 - NTE Electronics Даташит POWER Реле, DPDT, 24 В DC, 30 А, PANEL — Даташит
Наименование модели: R04-11D30-24
![]() Реле Мощности, Electromechanical Relay 24VDC 290Ω 30A DPDT (79.4x63.5x58.7)mm Open Frame Relay | |||
R04-11D30-24 NTE Electronics | 2 291 ₽ | ||
R04-11D30-24 NTE Electronics | 3 255 ₽ | ||
R04-11D30-24 | по запросу |
Производитель: NTE Electronics
Описание: POWER Реле, DPDT, 24 В DC, 30 А, PANEL
Features
Screw Terminals Long Life Contacts Molded Plastic Barrier Insulation Molded Nylon Bobbin Coil
R04 Series
Heavy Duty, 30 Amp, Open Frame Relay designed for Industrial Control, High Inrush Current Applications such as Motor Starting and Incandescent Lamp Loads.
- Coil Voltage VDC Nom: 24 В
- Contact Current Max: 30 А
- Contact Voltage AC Nom: 600 В
- Coil Resistance: 290 Ом
- Contacts: DPDT
- Coil Type: DC
- Nom Operating Power: 2 Вт
- Relay Mounting: Panel
R0411D3024, R04 11D30 24
