Datasheet R14-14A10-120 - NTE Electronics Даташит POWER Реле, 3PDT, 120 VAC, 10 А, PLUG IN — Даташит
Наименование модели: R14-14A10-120
Реле Мощности, NTE ELECTRONICS R14-14A10-120 Power Relay, 3PDT, 120VAC, 10A, R14 Series, Socket | |||
R14-14A10-120 NTE Electronics | 1 425 ₽ | ||
R14-14A10-120-RH3B-U120A | по запросу | ||
R14-14A10-120 | по запросу |
Производитель: NTE Electronics
Описание: POWER Реле, 3PDT, 120 VAC, 10 А, PLUG IN
Features
Slightly Larger than One Cubic Inch SPDT, DPDT, 3PDT, and 4PDT See-Thru Plastic Cover Plug-In or Solder Terminal, will also accept .187" (4.75mm) Faston Terminals PC Board Mount (P-suffix) Flange Mount Version (F-suffix) Indicator Lamp Types (N-suffix) High Reliability, 50 Million Operations
R14 Series
General Purpose 10 Amp & 15 Amp AC & DC Relays.
- Тип реле: General Purpose
- Coil Voltage VAC Nom: 120 В
- Contact Current Max: 10 А
- Contact Voltage AC Nom: 240 В
- Contact Voltage DC Nom: 30 В
- Contacts: 3PDT
- Coil Type: AC
- Nom Operating Power: 1.2 VA
R1414A10120, R14 14A10 120
