Datasheet G8P-1C4TP 5DC - Omron Даташит Реле, PCB, SPCO, 5 В DC — Даташит
Наименование модели: G8P-1C4TP 5DC
![]() 27 предложений от 17 поставщиков Промышленные/Универсальные Реле, Electromechanical Relay SPDT 20/10A 12VDC 155Ω Through Hole | |||
G8P-1C4TP-DC12 Omron | по запросу | ||
G8P-1C4TP-DC12 | по запросу | ||
G8P-1C4TP DC48 BY OMZ Omron | по запросу | ||
G8P-1C4TP DC24 BY OMZ Omron | по запросу |
Производитель: Omron
Описание: Реле, PCB, SPCO, 5 В DC
PCB Relay
Compact, Low-cost 30-A Power Relay for PC Board or Panel-mounted Applications
G8P
Compact, yet capable of switching up to 30-A loads.
Complies with UL873 and UL508 column A spacings (1/8" through air, 1/4" over surface). UL Class F insulation standard. Withstands of up to 6,000 V under 1.2 Ч 50 µs impulse wave or ring wave. A selection of contact forms: SPDT and SPSTNO. Quick-connect terminals versions ideal for PC board and panel mounting. Flanged mounting available. Ideal for home and industrial appliances, HVAC (heating, ventilating, and air conditioning), and many other applications. RoHS Compliant
Refer to pages 16 to 17 for details.
- Тип реле: Power
- Coil Voltage VDC Nom: 5 В
- Contact Current Max: 20 А
- Contact Voltage AC Nom: 250 В
- Contact Voltage DC Nom: 28 В
- Coil Resistance: 27 Ом
- Contact Configuration: SPDT
- Coil Type: DC Coil
- Coil Current: 185 мА
- Nom Operating Power: 900 мВт
- Relay Mounting: PC Board
- Внешняя длина / высота: 28.3 мм
- Внешняя ширина: 31.9 мм
- External Depth: 27.5 мм
- SVHC: No SVHC (18-Jun-2010)
- Contact Current AC Max: 20 А
- Contact Current DC Max: 20 А
- Contact Voltage AC Max: 250 В
- Contact Voltage DC Max: 28 В
- Mounting Type: PCB
- Number of Poles: 1
- Семейство: G8P
- Тип: Fully Sealed
- Approval Bodies: CSA
- Approval Category: UL Recognised
- Coil Operating Lower Percent Limit: 10%
- Coil Operating Upper Percent Limit: 75%
- Contact Current Rating: 20 А
- Contact Material: Ag Alloy
- Contact Resistance: 100 МОм
- DC Coil Power: 900 мВт
- Dielectric Voltage Coil to Contact: 2500 VAC
- Dielectric Voltage Contact to Contact: 1500 VAC
- Insulation Resistance: 100 МОм
- Рабочий диапазон температрур: -55°C ... 105°C
Дополнительные аксессуары:
- DURATOOL - HT-502C
G8P1C4TP 5DC, G8P 1C4TP 5DC
