Datasheet G2R-1-T 12VDC - Omron Даташит Реле, FLANGE, 12 В DC — Даташит
Наименование модели: G2R-1-T 12VDC
Power PCB Relay | |||
G2R1T12VDC | 38 546 ₽ | ||
G2R-1-T12VDC Omron | по запросу | ||
G2R-1-T-12VDC Omron | по запросу |
Производитель: Omron
Описание: Реле, FLANGE, 12 В DC
Back
PCB Relay
The Redesigned G2R Power Relay
Flux protection, pre-tinned terminals now standard.
High-sensitivity (360 mW) and high-capacity (16 A) types available. Double-winding latching type also available. Plug-in and quick-connect terminals available. Models meeting SEV and SEMKO, or VDE standards available.
G2R
- Тип реле: Power
- Coil Voltage VDC Nom: 12 В
- Contact Current Max: 10 А
- Contact Voltage AC Nom: 250 В
- Contact Voltage DC Nom: 30 В
- Coil Resistance: 275 Ом
- Contact Configuration: SPCO
- Coil Type: DC Coil, Monostable
- Coil Current: 43.6 мА
- Nom Operating Power: 530 мВт
- Relay Mounting: Bracket
- Внешняя длина / высота: 25.5 мм
- Внешняя ширина: 45 мм
- External Depth: 29.5 мм
- SVHC: No SVHC (18-Jun-2010)
- Contact Current AC Max: 10 А
- Contact Current DC Max: 10 А
- Contact Voltage AC Max: 250 В
- Contact Voltage DC Max: 30 В
- Mounting Type: PCB
- Number of Poles: 1
- Семейство: G2R
- Approval Bodies: TUV, VDE, SEV, SEMKO, NEMKO
- Coil Operating Lower Percent Limit: 70%
- Coil Operating Upper Percent Limit: 110%
- Contact Material: Silver Cadmium oxide
- DC Coil Power: 530 мВт
- Switch Current Max: 10 А
G2R1T 12VDC, G2R 1 T 12VDC
