Datasheet G2RV-SL500 DC24 - Omron Даташит Реле MODULE, SPDT, 24 В DC — Даташит
Наименование модели: G2RV-SL500 DC24
![]() Промышленные/Универсальные Реле, Electromechanical Relay 24VDC 1.8KΩ 6A SPDT Socket Slim Relay | |||
G2RVSL500DC24DC21 Omron | 785 ₽ | ||
G2RVSL500DC24DC21 Omron | 899 ₽ | ||
G2RVSL500DC24DC21 Omron | 962 ₽ | ||
G2RV-SL500-DC24DC21 | по запросу |
Производитель: Omron
Описание: Реле MODULE, SPDT, 24 В DC
Slim Relay
G2RV
The World's First Industrial Slim Relay
· Large plug-in terminals for reliable connection.
· LED indicator and mechanical flag to check operation. · Transparent housing enables checking relay condition. · Slim outline to save space. · Push-in terminals and accessories for easy wiring.
Model Number Structure
- Coil Voltage VDC Nom: 24 В
- Contact Current Max: 6 А
- Contact Voltage AC Nom: 250 В
- Contact Configuration: SPDT
- Coil Current: 13.3 мА
- Relay Mounting: Plug-In
- Внешняя длина / высота: 106.7 мм
- Внешняя ширина: 97.4 мм
- External Depth: 6.2 мм
- SVHC: No SVHC (18-Jun-2010)
- Contact Current AC Max: 6 А
- Contact Current DC Max: 6 А
- Contact Voltage AC Max: 250 В
- Contact Voltage DC Max: 30 В
- Mounting Type: Plug-In
- Number of Poles: 1
- Семейство: G2RV
- Approval Bodies: VDE, CE
- Approval Category: UL Recognised
- Average Coil Consumption: 300 мВт
- Contact Material: AgSnin
- Contact Resistance: 100 МОм
- Current Rating: 6 А
- DC Coil Power: 300 мВт
- Dielectric Voltage Coil to Contact: 4000 VAC
- Dielectric Voltage Contact to Contact: 1000 VAC
- Insulation Resistance: 1000 МОм
- Insulation Voltage: 500 V DC
- Operating Time: 20 мс
- Release Time: 40 мс
- Switching Current AC Max: 6 А
- Switching Current DC Max: 6 А
- Switching Power Max: 180 Вт
- Switching Voltage AC: 400 VAC
- Рабочий диапазон температрур: -40°C ... 55°C
G2RVSL500 DC24, G2RV SL500 DC24
