Datasheet G7J-3A1B-B 24DC - Omron Даташит Реле, 3PNO/SPNC, 24 В DC — Даташит
Наименование модели: G7J-3A1B-B 24DC
![]() 7 предложений от 4 поставщиков Промышленные/Универсальные Реле, Relay 3PST-NO/SPST-NC,25A/8A 24Vdc | |||
G7J3A1BB24DC Omron | 1 943 ₽ | ||
G7J3A1BB24DC Omron | 2 538 ₽ | ||
G7J3A1BB24DC Omron | 3 032 ₽ | ||
G7J-3A1B-B-24DC | от 5 869 ₽ |
Производитель: Omron
Описание: Реле, 3PNO/SPNC, 24 В DC
Power Relay
A High-capacity, High-dielectric-strength, Multi-pole Relay Used Like a Contactor
Miniature hinge for maximum switching power for motor loads as well as resistive and inductive loads.
No contact chattering for momentary voltage drops up to 50% of rated voltage. Withstanding more than 4 kV between contacts that are different in polarity and between the coil and contacts. Flame-resistant materials (UL94V-0-qualifying) used for all insulation material. Standard models approved by UL and CSA.
G7J
RC
- Тип реле: Power
- Coil Voltage VDC Nom: 24 В
- Contact Current Max: 25 А
- Contact Voltage AC Nom: 220 В
- Contact Voltage DC Nom: 30 В
- Coil Resistance: 288 Ом
- Contact Configuration: 3PNO / SPNC
- Coil Type: DC Coil
- Coil Current: 83 мА
- Nom Operating Power: 2 Вт
- Relay Mounting: Bracket
- Внешняя длина / высота: 34.5 мм
- Внешняя ширина: 51.5 мм
- External Depth: 34.5 мм
- SVHC: No SVHC (18-Jun-2010)
- Contact Current AC Max: 25 А
- Contact Voltage AC Max: 250 В
- Contact Voltage DC Max: 125 В
- Mounting Type: Bracket
- Number of Poles: 4
- Семейство: G7J
- Approval Bodies: UL, CSA
- Coil Operating Lower Percent Limit: 75%
- Coil Operating Upper Percent Limit: 110%
- Contact Resistance: 50 МОм
- DC Coil Power: 2 Вт
- Dielectric Strength VAC: 4000 VAC
- Insulation Resistance: 1000 МОм
- Number of Electrical Operations: 100000
- Number of Mechanical Operations: 1000000
- Operating Time: 50 мс
- Release Time: 50 мс
- Switch Current Max: 25 А
- Вес: 165 г
- Рабочий диапазон температрур: -25°C ... 60°C
G7J3A1BB 24DC, G7J 3A1B B 24DC
