Datasheet G7J-4A-B 24DC - Omron Даташит Реле, 4PNO, 24 В DC — Даташит
Omron G7J-4A-B 24DC
Наименование модели: G7J-4A-B 24DC
Промышленные/Универсальные Реле, Relay 4PST-NO screw-terminal 25A 24VDC
G7J4AB24DC
Omron
2 326 ₽
G7J4AB24DC
Omron
2 920 ₽
G7J4AB24DC
Omron
2 925 ₽
Производитель: Omron
Описание: Реле, 4PNO, 24 В DC
data sheetСкачать Data Sheet
Power Relay
A High-capacity, High-dielectric-strength, Multi-pole Relay Used Like a Contactor
Miniature hinge for maximum switching power for motor loads as well as resistive and inductive loads.
No contact chattering for momentary voltage drops up to 50% of rated voltage. Withstanding more than 4 kV between contacts that are different in polarity and between the coil and contacts. Flame-resistant materials (UL94V-0-qualifying) used for all insulation material. Standard models approved by UL and CSA.
G7J
RC
  • Тип реле: Power
  • Coil Voltage VDC Nom: 24 В
  • Contact Current Max: 25 А
  • Contact Voltage AC Nom: 220 В
  • Contact Voltage DC Nom: 30 В
  • Coil Resistance: 288 Ом
  • Contact Configuration: 4PNO
  • Coil Type: DC Coil
  • Coil Current: 83 мА
  • Nom Operating Power: 2 Вт
  • Relay Mounting: Bracket
  • Внешняя длина / высота: 64 мм
  • Внешняя ширина: 51.5 мм
  • External Depth: 34.5 мм
  • SVHC: No SVHC (18-Jun-2010)
  • Contact Current AC Max: 25 А
  • Contact Voltage AC Max: 250 В
  • Contact Voltage DC Max: 125 В
  • Mounting Type: Bracket
  • Number of Poles: 4
  • Семейство: G7J
  • Approval Bodies: UL, CSA
  • Coil Operating Lower Percent Limit: 75%
  • Coil Operating Upper Percent Limit: 110%
  • Contact Resistance: 50 МОм
  • DC Coil Power: 2 Вт
  • Dielectric Strength VAC: 4000 VAC
  • Insulation Resistance: 1000 МОм
  • Number of Electrical Operations: 100000
  • Number of Mechanical Operations: 1000000
  • Operating Time: 50 мс
  • Release Time: 50 мс
  • Switch Current Max: 25 А
  • Вес: 165 г
  • Рабочий диапазон температрур: -25°C ... 60°C
G7J4AB 24DC, G7J 4A B 24DC
На английском языке: Datasheet G7J-4A-B 24DC - Omron RELAY, 4PNO, 24 V DC
