Datasheet LY4 230 VAC - Omron Даташит Реле, PLUG-IN, 4PCO, 230 VAC — Даташит
Наименование модели: LY4 230 VAC
LY4-230-VAC Omron | 5 215 ₽ |
Производитель: Omron
Описание: Реле, PLUG-IN, 4PCO, 230 VAC
General-purpose Relay
LY
A Miniature Power Relay
· Equipped with arc barrier.
· Dielectric strength: 2,000 V. · Built-in diode models added to the LY Series. · Single-pole and double-pole models are applicable to operating coils with ratings of 100/110 VAC, 110/120 VAC, 200/220 VAC, 220/240 VAC, or 100/110 VDC). · Three-pole and four-pole models are applicable to operating coils with ratings of 100/110 VAC, 200/220 VAC, or 100/110 VDC).
LR
- Тип реле: General Purpose
- Coil Voltage VAC Nom: 230 В
- Contact Current Max: 10 А
- Contact Voltage AC Nom: 110 В
- Contact Voltage DC Nom: 24 В
- Coil Resistance: 9 кОм
- Contact Configuration: 4PCO
- Coil Type: AC Coil
- Nom Operating Power: 2.5 VA
- Relay Mounting: Plug-In
- Внешняя длина / высота: 28 мм
- Внешняя ширина: 41.5 мм
- External Depth: 36 мм
- SVHC: No SVHC (18-Jun-2010)
- Contact Current AC Max: 10 А
- Contact Current DC Max: 10 А
- Contact Voltage AC Max: 230 В
- Mounting Type: Plug-In
- Number of Poles: 4
- Семейство: LY
- Approval Bodies: UL, CSA, VDE
- Coil Operating Lower Percent Limit: 85%
- Coil Operating Upper Percent Limit: 110%
- Contact Material: Silver Cadmium Oxide
- Dielectric Strength VDC: 2000 В
- Switch Current Max: 10 А
- Рабочий диапазон температрур: -5°C ... 45°C
Дополнительные аксессуары:
- Omron - PT14-0
- Omron - PT14
- Omron - PTF14AE
