Datasheet MY2K 24DC - Omron Даташит Реле, DPCO, 24 В DC, LATCHING — Даташит
Omron MY2K 24DC
Наименование модели: MY2K 24DC
T-electron
MY2K24DC
218 972 ₽
MY2K24DC
Omron
МосЧип
MY2K-24DC
Omron
Производитель: Omron
Описание: Реле, DPCO, 24 В DC, LATCHING
data sheetСкачать Data Sheet
General-purpose Latching Relay
MYK
Magnetic Latching Relay Ideal for Memory and Data Transmission Circuits
· Double-winding latch system that holds residual magnetism.
· Changes due to aging are negligible because of use of special magnetic materials, thus ensuring long continuous holding time. · Little change in characteristics such as contact follow, contact pressure, etc., throughout its long life. · Excellent vibration/shock resistance. · Easy monitoring of ON/OFF operation thanks to the built-in operation indicator mechanism. · Same outline dimensions as the MY Miniature Power Relay.
Ordering Information
  • Тип реле: General Purpose
  • Coil Voltage VDC Nom: 24 В
  • Contact Current Max: 3 А
  • Contact Voltage AC Nom: 220 В
  • Contact Voltage DC Nom: 24 В
  • Coil Resistance: 650 Ом
  • Contact Configuration: DPCO
  • Coil Type: DC Coil
  • Coil Current: 52 мА
  • Nom Operating Power: 1.3 Вт
  • Relay Mounting: Plug-In
  • Внешняя длина / высота: 28 мм
  • Внешняя ширина: 21.5 мм
  • External Depth: 36 мм
  • SVHC: No SVHC (18-Jun-2010)
  • Contact Current AC Max: 10 А
  • Contact Current DC Max: 10 А
  • Contact Voltage AC Max: 250 В
  • Contact Voltage DC Max: 30 В
  • Mounting Type: Plug-In
  • Number of Poles: 2
  • Семейство: MYK
  • AC Coil Power: 1.2 VA
  • Approval Bodies: UL, CSA, VDE
  • Coil Operating Lower Percent Limit: 80%
  • Coil Operating Upper Percent Limit: 110%
  • Contact Material: Silver
  • DC Coil Power: 0.9 Вт
  • Operating Time: 20 мс
  • Release Time: 20 мс
  • Switch Current Max: 5 А
  • Рабочий диапазон температрур: -55°C ... 70°C
Дополнительные аксессуары:
  • Phoenix Contact - E/UK
На английском языке: Datasheet MY2K 24DC - Omron RELAY, DPCO, 24 V DC, LATCHING
