Datasheet MY2N 220/240ACS - Omron Даташит Реле, DPCO, 220 VAC — Даташит
Наименование модели: MY2N 220/240ACS
General-purpose Relay | |||
MY2N220240ACS Omron | 911 ₽ | ||
MY2N220/240ACS Omron | по запросу | ||
MY2N-220/240AC Omron | по запросу |
Производитель: Omron
Описание: Реле, DPCO, 220 VAC
An Improved Miniature Power Relay with Many Models for Sequence Control and Power Applications
A wide range of relay variations including ones with operation indicators, high-capacity capability, built-in diodes, etc.
Arc barrier standard on 3- and 4-pole relays. Withstand voltage: 2,000 VAC.
MY
Ordering Information
- Тип реле: General Purpose
- Coil Voltage VAC Nom: 240 В
- Contact Current Max: 10 А
- Contact Voltage AC Nom: 250 В
- Contact Voltage DC Nom: 30 В
- Coil Resistance: 18.79 кОм
- Contact Configuration: DPCO
- Coil Type: AC Coil
- Coil Current: 5.3 мА
- Nom Operating Power: 1.1 VA
- Relay Mounting: Plug-In
- Внешняя длина / высота: 28 мм
- Внешняя ширина: 21.5 мм
- External Depth: 36 мм
- SVHC: No SVHC (18-Jun-2010)
- Contact Current AC Max: 10 А
- Contact Current DC Max: 10 А
- Contact Voltage AC Max: 250 В
- Contact Voltage DC Max: 30 В
- Mounting Type: Plug-In
- Number of Poles: 2
- Семейство: MY
- AC Coil Power: 1.2 VA
- Approval Bodies: UL, CSA, VDE
- Coil Operating Lower Percent Limit: 80%
- Coil Operating Upper Percent Limit: 110%
- Contact Material: Silver
- DC Coil Power: 0.9 Вт
- Operating Time: 20 мс
- Release Time: 20 мс
- Switch Current Max: 5 А
- Рабочий диапазон температрур: -55°C ... 70°C
