Datasheet MY2N 24DCS - Omron Даташит Реле, DPCO, 24 В DC — Даташит
Наименование модели: MY2N 24DCS
![]() General-purpose Relay | |||
MY2N24DCS Omron | 824 ₽ | ||
MY2N-24DC(S) Omron | 1 569 ₽ | ||
MY2N24DCS Omron | по запросу | ||
MY2N-24DC Omron | по запросу |
Производитель: Omron
Описание: Реле, DPCO, 24 В DC
An Improved Miniature Power Relay with Many Models for Sequence Control and Power Applications
A wide range of relay variations including ones with operation indicators, high-capacity capability, built-in diodes, etc.
Arc barrier standard on 3- and 4-pole relays. Withstand voltage: 2,000 VAC.
MY
Ordering Information
- Тип реле: General Purpose
- Coil Voltage VDC Nom: 24 В
- Contact Current Max: 10 А
- Contact Voltage AC Nom: 250 В
- Contact Voltage DC Nom: 30 В
- Coil Resistance: 636 Ом
- Contact Configuration: DPCO
- Coil Type: DC Coil
- Coil Current: 37.7 мА
- Nom Operating Power: 900 мВт
- Relay Mounting: Plug-In
- Внешняя длина / высота: 28 мм
- Внешняя ширина: 21.5 мм
- External Depth: 36 мм
- SVHC: No SVHC (18-Jun-2010)
- Contact Current AC Max: 10 А
- Contact Current DC Max: 10 А
- Contact Voltage AC Max: 250 В
- Contact Voltage DC Max: 30 В
- Mounting Type: Plug-In
- Number of Poles: 2
- Семейство: MY
- AC Coil Power: 1.2 VA
- Approval Bodies: UL, CSA, VDE
- Coil Operating Lower Percent Limit: 80%
- Coil Operating Upper Percent Limit: 110%
- Contact Material: Silver
- DC Coil Power: 0.9 Вт
- Operating Time: 20 мс
- Release Time: 20 мс
- Switch Current Max: 5 А
- Рабочий диапазон температрур: -55°C ... 70°C
