Datasheet MY4 02 220/240AC - Omron Даташит Реле, PCB, 4PCO, 220/240 VAC — Даташит
Omron MY4 02 220/240AC
Наименование модели: MY4 02 220/240AC
Элитан
MY4-02-220/240AC
Omron
2 457 ₽
MY402220240AC
Omron
TradeElectronics
MY4-02220/240AC
Omron
Производитель: Omron
Описание: Реле, PCB, 4PCO, 220/240 VAC
data sheetСкачать Data Sheet
General-purpose Relay
MY New model
Versatile and Function-filled Miniature Power Relay for Sequence Control and Power Switching Applications
· Models with lockable test buttons now available.
· Many variations possible through a selection of operation indicators (mechanical and LED indicators), lockable test button, built-in diode and CR (surge suppression), bifurcated contacts, etc. · Arc barrier standard on 4-pole Relays. · Dielectric strength: 2,000 VAC (coil to contact) · Environment-friendly cadmium-free contacts. · Safety standard approvals obtained. · Wide range of Sockets (PY, PYF Series) and optional parts are available. · Max. Switching Current: 2-pole: 10 A, 4-pole: 5 A · Provided with nameplate.
LR
  • Тип реле: General Purpose
  • Coil Voltage VAC Nom: 240 В
  • Contact Current Max: 5 А
  • Contact Voltage AC Nom: 250 В
  • Contact Voltage DC Nom: 30 В
  • Coil Resistance: 18.8 Ом
  • Contact Configuration: 4PCO
  • Coil Type: AC Coil
  • Coil Current: 5.3 мА
  • Nom Operating Power: 1.1 VA
  • Relay Mounting: Plug-In
  • Внешняя длина / высота: 28 мм
  • Внешняя ширина: 21.5 мм
  • External Depth: 35.5 мм
  • SVHC: No SVHC (18-Jun-2010)
  • Contact Current AC Max: 5 А
  • Contact Current DC Max: 5 А
  • Contact Voltage AC Max: 240 В
  • Contact Voltage DC Max: 30 В
  • Mounting Type: Plug-In
  • Number of Poles: 4
  • Семейство: MY
  • AC Coil Power: 1.2 VA
  • Coil Operating Lower Percent Limit: 80%
  • Coil Operating Upper Percent Limit: 110%
  • Contact Material: Silver
  • Contact Plating: Gold
  • DC Coil Power: 0.9 Вт
  • Operating Time: 20 мс
  • Release Time: 20 мс
  • Switch Current Max: 3 А
  • Рабочий диапазон температрур: -25°C ... 70°C
На английском языке: Datasheet MY4 02 220/240AC - Omron RELAY, PCB, 4PCO, 220/240 VAC
