Datasheet MY4 48/50VAC (S) - Omron Даташит Реле, 4PCO, 48/50 VAC — Даташит
Omron MY4 48/50VAC (S)
Наименование модели: MY4 48/50VAC (S)
MY448/50VAC(S)
Omron
Производитель: Omron
Описание: Реле, 4PCO, 48/50 VAC
data sheetСкачать Data Sheet
General-purpose Relay
An Improved Miniature Power Relay with Many Models for Sequence Control and Power Applications
A wide range of relay variations including ones with operation indicators, high-capacity capability, built-in diodes, etc.
Arc barrier standard on 3- and 4-pole relays. Withstand voltage: 2,000 VAC.
MY
Ordering Information
  • Тип реле: General Purpose
  • Coil Voltage VAC Nom: 50 В
  • Contact Current Max: 5 А
  • Contact Voltage AC Nom: 250 В
  • Contact Voltage DC Nom: 30 В
  • Coil Resistance: 788 Ом
  • Contact Configuration: 4PCO
  • Coil Type: AC Coil
  • Coil Current: 25.7 мА
  • Nom Operating Power: 1.2 VA
  • Relay Mounting: Plug-In
  • Внешняя длина / высота: 28 мм
  • Внешняя ширина: 21.5 мм
  • External Depth: 36 мм
  • SVHC: No SVHC (18-Jun-2010)
  • Contact Current AC Max: 5 А
  • Contact Current DC Max: 5 А
  • Contact Voltage AC Max: 250 В
  • Contact Voltage DC Max: 30 В
  • Mounting Type: Plug-In
  • Number of Poles: 4
  • Семейство: MY
  • AC Coil Power: 1.2 VA
  • Approval Bodies: UL, CSA, VDE
  • Coil Operating Lower Percent Limit: 80%
  • Coil Operating Upper Percent Limit: 110%
  • Contact Material: Silver, Gold Flashed
  • DC Coil Power: 0.9 Вт
  • Operating Time: 20 мс
  • Release Time: 20 мс
  • Switch Current Max: 3 А
  • Рабочий диапазон температрур: -55°C ... 70°C
На английском языке: Datasheet MY4 48/50VAC (S) - Omron RELAY, 4PCO, 48/50 VAC
