Datasheet MY4IN 220/240ACS - Omron Даташит Реле, 4PCO, 220 VAC — Даташит
Наименование модели: MY4IN 220/240ACS
General-purpose Relay | |||
MY4IN-220/240ACS Omron | 4 899 ₽ | ||
MY4IN-220/240AC Omron | по запросу | ||
MY4IN220/240ACS Omron | по запросу |
Производитель: Omron
Описание: Реле, 4PCO, 220 VAC
MY New model
Versatile and Function-filled Miniature Power Relay for Sequence Control and Power Switching Applications
· Models with lockable test buttons now available.
· Many variations possible through a selection of operation indicators (mechanical and LED indicators), lockable test button, built-in diode and CR (surge suppression), bifurcated contacts, etc. · Arc barrier standard on 4-pole Relays. · Dielectric strength: 2,000 VAC (coil to contact) · Environment-friendly cadmium-free contacts. · Safety standard approvals obtained. · Wide range of Sockets (PY, PYF Series) and optional parts are available. · Max. Switching Current: 2-pole: 10 A, 4-pole: 5 A · Provided with nameplate.
LR
- Тип реле: General Purpose
- Coil Voltage VAC Nom: 240 В
- Contact Current Max: 5 А
- Contact Voltage AC Nom: 250 В
- Contact Voltage DC Nom: 30 В
- Coil Resistance: 18.79 кОм
- Contact Configuration: 4PCO
- Coil Type: AC Coil
- Coil Current: 5.3 мА
- Nom Operating Power: 1.1 VA
- Relay Mounting: Plug-In
- Внешняя длина / высота: 28 мм
- Внешняя ширина: 21.5 мм
- External Depth: 36 мм
- SVHC: No SVHC (18-Jun-2010)
- Contact Current AC Max: 5 А
- Contact Current DC Max: 5 А
- Contact Voltage AC Max: 250 В
- Contact Voltage DC Max: 30 В
- Mounting Type: Plug-In
- Number of Poles: 4
- Семейство: MY
- AC Coil Power: 1.2 VA
- Approval Bodies: UL, CSA, VDE
- Coil Operating Lower Percent Limit: 80%
- Coil Operating Upper Percent Limit: 110%
- Contact Material: Silver, Gold Flashed
- DC Coil Power: 0.9 Вт
- Operating Time: 20 мс
- Release Time: 20 мс
- Switch Current Max: 3 А
- Рабочий диапазон температрур: -55°C ... 70°C
