Datasheet G7L-1A-TUB-J-CB-AC200/240 - Omron Даташит POWER Реле SPST-NO 240 VAC, 30 А, BRACKET — Даташит
Omron G7L-1A-TUB-J-CB-AC200/240
Наименование модели: G7L-1A-TUB-J-CB-AC200/240
17 предложений от 11 поставщиков
Несгруппированные, Relay; E-Mech; SPST-NO; Ctrl-V 200/240AC; 30A; 250VAC; Panel Mount; QC Term; G7L Series
G7L-1A-TUBJCBAC200/240
Omron
G7L-1A-TUBJ-CB-AC200-240
Omron
ТаймЧипс
Omron
Производитель: Omron
Описание: POWER Реле SPST-NO 240 VAC, 30 А, BRACKET
data sheetСкачать Data Sheet
Power Relay
G7L
A High-capacity, High-dielectric-strength Relay Compatible with Momentary Voltage Drops
· No contact chattering for momentary voltage drops up to 50% of rated voltage.
· Wide-range AC-activated coil that handles 100 to 120 or 200 to 240 VAC at either 50 or 60 Hz. · Miniature hinge for maximum switching power, particularly for inductive loads. · Flame-resistance materials (UL94V-0-qualifying) used for all insulation material. · Quick-connect, screw, and PCB terminals, and DIN track mounting available.
Model Number Structure
  • Тип реле: High Capacity
  • Coil Voltage VAC Nom: 240 В
  • Contact Current Max: 30 А
  • Contact Voltage AC Nom: 220 В
  • Coil Resistance: 21000 Ом
  • Contacts: SPST-NO
  • Coil Type: AC
  • Coil Current: 10.2 мА
G7L1ATUBJCBAC200/240, G7L 1A TUB J CB AC200/240
На английском языке: Datasheet G7L-1A-TUB-J-CB-AC200/240 - Omron POWER RELAY SPST-NO 240 VAC, 30 A, BRACKET
