Datasheet G7L-2A-BUB-J-CB-AC200/240 - Omron Даташит POWER Реле DPST-NO 240 VAC, 25 А, BRACKET — Даташит
Наименование модели: G7L-2A-BUB-J-CB-AC200/240
![]() 11 предложений от 8 поставщиков Реле Мощности, Electromechanical Relay 200/240VAC 21KΩ 25A DPST-NO( (68.5mm 34.5mm 49mm)) Bracket General Purpose Relay | |||
G7L-2A-BUBJ-CB-AC200/240 Omron | 904 ₽ | ||
G7L-2A-BUBJ-CBAC200/240 Omron | 2 502 ₽ | ||
G7L-2A-BUBJ-CB-AC200/240 Omron | от 2 665 ₽ | ||
G7L-2A-BUBJ-CB-AC200/240 Omron | по запросу |
Производитель: Omron
Описание: POWER Реле DPST-NO 240 VAC, 25 А, BRACKET
Power Relay
G7L
A High-capacity, High-dielectric-strength Relay Compatible with Momentary Voltage Drops
· No contact chattering for momentary voltage drops up to 50% of rated voltage.
· Wide-range AC-activated coil that handles 100 to 120 or 200 to 240 VAC at either 50 or 60 Hz. · Miniature hinge for maximum switching power, particularly for inductive loads. · Flame-resistance materials (UL94V-0-qualifying) used for all insulation material. · Quick-connect, screw, and PCB terminals, and DIN track mounting available.
Model Number Structure
- Тип реле: High Capacity
- Coil Voltage VAC Nom: 240 В
- Contact Current Max: 25 А
- Contact Voltage AC Nom: 220 В
- Coil Resistance: 21000 Ом
- Contacts: DPST-NO
- Coil Type: AC
- Coil Current: 10.2 мА
G7L2ABUBJCBAC200/240, G7L 2A BUB J CB AC200/240
