Datasheet LY2N-AC200/220 - Omron Даташит POWER Реле, DPDT, 220 VAC, 10 А, PLUG IN — Даташит
Наименование модели: LY2N-AC200/220
![]() 15 предложений от 8 поставщиков Промышленные/Универсальные Реле, Electromechanical Relay 200/220VAC 12.95KΩ 10A DPDT (28x21.5x42.4)mm Socket General Purpose Relay | |||
LY2NAC200220 Omron | 774 ₽ | ||
LY2N-AC200/220 Omron | 1 359 ₽ | ||
LY2N-AC200/220 Omron | 1 974 ₽ | ||
LY2N-AC200/220 Omron | от 2 031 ₽ |
Производитель: Omron
Описание: POWER Реле, DPDT, 220 VAC, 10 А, PLUG IN
LY
· Arc barrier equipped.
· High dielectric strength (2,000 VAC). · Long dependable service life assured by Ag-Alloy contacts. · Choose models with single or bifurcated contacts, LED indicator, diode surge suppression, push-to-test button, or RC circuit. · UL, CSA, TUV, and CE approvals on all standard LY Relay Part Numbers.
Ordering Information
To Order: Select the part number and add the desired coil voltage rating (e.g., LY1-DC6). Type Terminal Contact form Model Single contact Standard bracket mounting Standard Plug-in/solder SPDT DPDT 3PDT 4PDT PCB SPDT DPDT 3PDT 4PDT LED indicator Plug-in/solder SPDT DPDT 3PDT 4PDT Diode surge suppression SPDT DPDT 3PDT 4PDT LED indicator and diode surge suppression RC circuit LED indicator and RC circuit SPDT DPDT 4PDT SPDT DPDT SPDT DPDT LY1 LY2 LY3 LY4 LY1-0 LY2-0 LY3-0 LY4-0 LY1N LY2N LY3N LY4N LY1-D LY2-D LY3-D LY4-D LY1N-D2 LY2N-D2 LY4N-D2 LY1-CR LY2-CR LY1N-CR LY2N-CR Upper mounting bracket LY1F LY2F LY3F LY4F -- -
- Тип реле: General Purpose
- Coil Voltage VAC Nom: 220 В
- Contact Current Max: 10 А
- Contact Voltage AC Nom: 110 В
- Contact Voltage DC Nom: 24 В
- Coil Resistance: 12950 Ом
- Contacts: DPDT
- Coil Type: AC
LY2NAC200/220, LY2N AC200/220
