Datasheet MK2KP-UA-DC12 - Omron Даташит POWER Реле, DPDT, 12 В DC, 10 А, PLUG IN — Даташит
Omron MK2KP-UA-DC12
Наименование модели: MK2KP-UA-DC12
12 предложений от 9 поставщиков
Реле общего назначения Relay10A Gen.Purpse 12 VDC (Coil); DPDT
MK2KP-UA-DC12
4 936 ₽
MK2KP-UA-DC12
Omron
5 792 ₽
MK2KP-UA-DC12
Omron
MK2KP-UA-DC12
Производитель: Omron
Описание: POWER Реле, DPDT, 12 В DC, 10 А, PLUG IN
data sheetСкачать Data Sheet
General Purpose Relay
MK
· Exceptionally reliable general purpose relay.
· Long life (minimum 100,000 electrical operations) assured by silver contacts. · Built-in operation indicator (mechanical, LED), diode surge suppression, Varistor surge suppression. · The contact operation can be easily checked by mechanical indicator and/or push-to-test button options. · Conforms to CENELEC standards. · VDE approved versions available.
Ordering Information
To Order: Select the part number and add the desired coil voltage rating (e.g., MK3P5-S-AC120). Type Terminal Coil Contact form Mechanical indicator Standard LED indicator LED indicator and diode LED indicator and varistor Diode Varistor DC AC DC AC Plug-in AC/DC DPDT 3PDT DPDT 3PDT DPDT 3PDT DPDT 3PDT DPDT 3PDT DPDT 3PDT MK2P-I MK3P-5-I MK2PN-I MK3PN-5-I MK2PND-I MK3PND-5-I MK2PNV-I MK3PNV-5-I MK2PD-I MK3PD-5-I MK2PV-I MK3PV-5-I Model Mechanical indicator & push-to-test button MK2P-S MK3P-5-S MK2PN-S MK3PN-5-S MK2PND-S MK3PND-5-S MK2PNV-S M
  • Тип реле: General Purpose
  • Coil Voltage VDC Nom: 12 В
  • Contact Current Max: 10 А
  • Contact Voltage AC Nom: 250 В
  • Contact Voltage DC Nom: 28 В
  • Coil Resistance: 95 Ом
  • Contacts: DPDT
  • Coil Type: DC
MK2KPUADC12, MK2KP UA DC12
На английском языке: Datasheet MK2KP-UA-DC12 - Omron POWER RELAY, DPDT, 12 V DC, 10 A, PLUG IN
