Datasheet MKS2PI AC12 - Omron Даташит POWER Реле, DPDT, 12 VAC, 10 А, PLUG IN — Даташит
Omron MKS2PI AC12
Наименование модели: MKS2PI AC12
Несгруппированные, Relay; E-Mech; DPDT; Ctrl-V 12AC; 10A; 250VAC; Socket Mount; 8Pin Octal; MK-S Series
MKS2PIAC12
Omron
822 ₽
MKS2PIAC12
Omron
852 ₽
MKS2PIAC12
Omron
905 ₽
Элитан
MKS2PIAC12
Omron
3 271 ₽
Производитель: Omron
Описание: POWER Реле, DPDT, 12 VAC, 10 А, PLUG IN
data sheetСкачать Data Sheet
General Purpose Relays
MKS
Exceptionally Reliable General Purpose Relay now available with Lockable Test Button
· IEC Rating of 7A 250 V AC 50/60 Hz, General use 100,000 cycles.
· Mechanical indicator standard for all models. · Optional features include lockable test button, LED indicator, diode surge suppression, varistor, reverse polarity, and alternate wiring styles. · UL (RU/CRU), CE and TUV approved. · RoHS Compliant.
Features
  • Тип реле: General Purpose
  • Coil Voltage VAC Nom: 12 В
  • Contact Current Max: 10 А
  • Contact Voltage AC Nom: 250 В
  • Contact Voltage DC Nom: 30 В
  • Coil Resistance: 13.7 Ом
  • Contacts: DPDT
  • Coil Type: AC
На английском языке: Datasheet MKS2PI AC12 - Omron POWER RELAY, DPDT, 12 VAC, 10 A, PLUG IN
