Datasheet MKS2PI AC240 - Omron Даташит POWER Реле, DPDT, 240 VAC, 10 А, PLUG IN — Даташит
Наименование модели: MKS2PI AC240
![]() 16 предложений от 8 поставщиков Реле Мощности, Electromechanical Relay 240VAC 4.48KΩ 10A DPDT(34.5x34.5x53.3)mm Plug-In General Purpose Relay | |||
MKS2PIAC240 Omron | 905 ₽ | ||
MKS2PIAC240 Omron | 963 ₽ | ||
MKS2PIAC240 Omron | от 3 838 ₽ | ||
MKS2PI-AC240 Omron | по запросу |
Производитель: Omron
Описание: POWER Реле, DPDT, 240 VAC, 10 А, PLUG IN
General Purpose Relays
MKS
Exceptionally Reliable General Purpose Relay now available with Lockable Test Button
· IEC Rating of 7A 250 V AC 50/60 Hz, General use 100,000 cycles.
· Mechanical indicator standard for all models. · Optional features include lockable test button, LED indicator, diode surge suppression, varistor, reverse polarity, and alternate wiring styles. · UL (RU/CRU), CE and TUV approved. · RoHS Compliant.
Features
- Тип реле: General Purpose
- Coil Voltage VAC Nom: 240 В
- Contact Current Max: 10 А
- Contact Voltage AC Nom: 250 В
- Contact Voltage DC Nom: 30 В
- Coil Resistance: 4480 Ом
- Contacts: DPDT
- Coil Type: AC
