Datasheet MKS2PIN AC24 - Omron Даташит POWER Реле, DPDT, 24 VAC, 10 А, PLUG IN — Даташит
Omron MKS2PIN AC24
Наименование модели: MKS2PIN AC24
Реле Мощности, Relay with Latching Lever Adder 24VAC Coil 8Pin Octal Terminal 250VAC 10A 2 Poles DPDT
MKS2PINAC24
Omron
967 ₽
MKS2PINAC24
Omron
1 108 ₽
MKS2PINAC24
Omron
1 179 ₽
Элитан
MKS2PINAC24
Omron
4 443 ₽
Производитель: Omron
Описание: POWER Реле, DPDT, 24 VAC, 10 А, PLUG IN
data sheetСкачать Data Sheet
General Purpose Relays
MKS
Exceptionally Reliable General Purpose Relay now available with Lockable Test Button
· IEC Rating of 7A 250 V AC 50/60 Hz, General use 100,000 cycles.
· Mechanical indicator standard for all models. · Optional features include lockable test button, LED indicator, diode surge suppression, varistor, reverse polarity, and alternate wiring styles. · UL (RU/CRU), CE and TUV approved. · RoHS Compliant.
Features
  • Тип реле: General Purpose
  • Coil Voltage VAC Nom: 24 В
  • Contact Current Max: 10 А
  • Contact Voltage AC Nom: 250 В
  • Contact Voltage DC Nom: 30 В
  • Coil Resistance: 48.4 Ом
  • Contacts: DPDT
  • Coil Type: AC
На английском языке: Datasheet MKS2PIN AC24 - Omron POWER RELAY, DPDT, 24 VAC, 10 A, PLUG IN
