Datasheet MKS2PIN DC24 - Omron Даташит POWER Реле, DPDT, 24 В DC, 10 А, PLUG IN — Даташит
Omron MKS2PIN DC24
Наименование модели: MKS2PIN DC24
, Electromechanical Relay 24VDC 430Ω 10A DPDT(34.5x34.5x53.3)mm Plug-In General Purpose Relay
MKS2PINDC24
Omron
665 ₽
MKS2PINDC24
Omron
1 065 ₽
MKS2PINDC24
Omron
1 132 ₽
Элитан
MKS2PINDC24
Omron
3 251 ₽
Производитель: Omron
Описание: POWER Реле, DPDT, 24 В DC, 10 А, PLUG IN
data sheetСкачать Data Sheet
General Purpose Relays
MKS
Exceptionally Reliable General Purpose Relay now available with Lockable Test Button
· IEC Rating of 7A 250 V AC 50/60 Hz, General use 100,000 cycles.
· Mechanical indicator standard for all models. · Optional features include lockable test button, LED indicator, diode surge suppression, varistor, reverse polarity, and alternate wiring styles. · UL (RU/CRU), CE and TUV approved. · RoHS Compliant.
Features
  • Тип реле: General Purpose
  • Coil Voltage VDC Nom: 24 В
  • Contact Current Max: 10 А
  • Contact Voltage AC Nom: 250 В
  • Contact Voltage DC Nom: 30 В
  • Coil Resistance: 430 Ом
  • Contacts: DPDT
  • Coil Type: DC
На английском языке: Datasheet MKS2PIN DC24 - Omron POWER RELAY, DPDT, 24 V DC, 10 A, PLUG IN
