Datasheet MKS3PI-5 AC120 - Omron Даташит POWER Реле, 3PDT, 120 VAC, 10 А, PLUG IN — Даташит
Omron MKS3PI-5 AC120
Наименование модели: MKS3PI-5 AC120
Промышленные/Универсальные Реле, Electromechanical Relay 120VAC 10A 3PDT(34.5x34.5x53.3)mm Plug-In General Purpose Relay
MKS3PI5AC120
Omron
681 ₽
MKS3PI5AC120
Omron
681 ₽
MKS3PI5-AC120
1 494 ₽
ТаймЧипс
MKS3PI5-AC120
Omron
Производитель: Omron
Описание: POWER Реле, 3PDT, 120 VAC, 10 А, PLUG IN
data sheetСкачать Data Sheet
General Purpose Relays
MKS
Exceptionally Reliable General Purpose Relay now available with Lockable Test Button
· IEC Rating of 7A 250 V AC 50/60 Hz, General use 100,000 cycles.
· Mechanical indicator standard for all models. · Optional features include lockable test button, LED indicator, diode surge suppression, varistor, reverse polarity, and alternate wiring styles. · UL (RU/CRU), CE and TUV approved. · RoHS Compliant.
Features
  • Тип реле: General Purpose
  • Coil Voltage VAC Nom: 120 В
  • Contact Current Max: 10 А
  • Contact Voltage AC Nom: 250 В
  • Contact Voltage DC Nom: 30 В
  • Coil Resistance: 1130 Ом
  • Contacts: 3PDT
  • Coil Type: AC
MKS3PI5 AC120, MKS3PI 5 AC120
На английском языке: Datasheet MKS3PI-5 AC120 - Omron POWER RELAY, 3PDT, 120 VAC, 10 A, PLUG IN
