Datasheet MKS3PI-5 AC24 - Omron Даташит POWER Реле, 3PDT, 24 VAC, 10 А, PLUG IN — Даташит
Наименование модели: MKS3PI-5 AC24
![]() 6 предложений от 6 поставщиков Реле Мощности, Electromechanical Relay 24VAC 48.4Ω 10A 3PDT(34.5x34.5x53.3)mm Plug-In General Purpose Relay | |||
MKS3PI5AC24 Omron | 626 ₽ | ||
MKS3PI5AC24 Omron | 963 ₽ | ||
MKS3PI5AC24 Omron | 2 464 ₽ | ||
MKS3PI5AC24 Omron | 4 317 ₽ |
Производитель: Omron
Описание: POWER Реле, 3PDT, 24 VAC, 10 А, PLUG IN
General Purpose Relays
MKS
Exceptionally Reliable General Purpose Relay now available with Lockable Test Button
· IEC Rating of 7A 250 V AC 50/60 Hz, General use 100,000 cycles.
· Mechanical indicator standard for all models. · Optional features include lockable test button, LED indicator, diode surge suppression, varistor, reverse polarity, and alternate wiring styles. · UL (RU/CRU), CE and TUV approved. · RoHS Compliant.
Features
- Тип реле: General Purpose
- Coil Voltage VAC Nom: 24 В
- Contact Current Max: 10 А
- Contact Voltage AC Nom: 250 В
- Contact Voltage DC Nom: 30 В
- Coil Resistance: 48.4 Ом
- Contacts: 3PDT
- Coil Type: AC
MKS3PI5 AC24, MKS3PI 5 AC24
