Datasheet MKS3PI-5 AC240 - Omron Даташит POWER Реле, 3PDT, 240 VAC, 10 А, PLUG IN — Даташит
Omron MKS3PI-5 AC240
Наименование модели: MKS3PI-5 AC240
, Electromechanical Relay 240VAC 4.48KΩ 10A 3PDT(34.5x34.5x53.3)mm Plug-In General Purpose Relay
MKS3PI5AC240
Omron
704 ₽
MKS3PI5AC240
Omron
1 159 ₽
MKS3PI5AC240
Omron
1 232 ₽
Элитан
MKS3PI-5AC240
Omron
2 937 ₽
Производитель: Omron
Описание: POWER Реле, 3PDT, 240 VAC, 10 А, PLUG IN
data sheetСкачать Data Sheet
General Purpose Relays
MKS
Exceptionally Reliable General Purpose Relay now available with Lockable Test Button
· IEC Rating of 7A 250 V AC 50/60 Hz, General use 100,000 cycles.
· Mechanical indicator standard for all models. · Optional features include lockable test button, LED indicator, diode surge suppression, varistor, reverse polarity, and alternate wiring styles. · UL (RU/CRU), CE and TUV approved. · RoHS Compliant.
Features
  • Тип реле: General Purpose
  • Coil Voltage VAC Nom: 240 В
  • Contact Current Max: 10 А
  • Contact Voltage AC Nom: 250 В
  • Contact Voltage DC Nom: 30 В
  • Coil Resistance: 4480 Ом
  • Contacts: 3PDT
  • Coil Type: AC
MKS3PI5 AC240, MKS3PI 5 AC240
На английском языке: Datasheet MKS3PI-5 AC240 - Omron POWER RELAY, 3PDT, 240 VAC, 10 A, PLUG IN
