Datasheet MKS3PIN-5 AC120 - Omron Даташит POWER Реле, 3PDT, 120 VAC, 10 А, PLUG IN — Даташит
Наименование модели: MKS3PIN-5 AC120
Купить MKS3PIN-5 AC120 на РадиоЛоцман.Цены — от 721 до 4 029 ₽ , Electromechanical Relay 120VAC 10A 3PDT(34.5x34.5x53.3)mm Plug-In General Purpose Relay | |||
| MKS3PIN5AC120 Omron | 721 ₽ | ||
| MKS3PIN-5AC120 Omron | 1 174 ₽ | ||
| MKS3PIN-5-AC120 Omron | 4 029 ₽ | ||
Производитель: Omron
Описание: POWER Реле, 3PDT, 120 VAC, 10 А, PLUG IN
General Purpose Relays
MKS
Exceptionally Reliable General Purpose Relay now available with Lockable Test Button
· IEC Rating of 7A 250 V AC 50/60 Hz, General use 100,000 cycles.
· Mechanical indicator standard for all models. · Optional features include lockable test button, LED indicator, diode surge suppression, varistor, reverse polarity, and alternate wiring styles. · UL (RU/CRU), CE and TUV approved. · RoHS Compliant.
Features
- Тип реле: General Purpose
- Coil Voltage VAC Nom: 120 В
- Contact Current Max: 10 А
- Contact Voltage AC Nom: 250 В
- Contact Voltage DC Nom: 30 В
- Coil Resistance: 1130 Ом
- Contacts: 3PDT
- Coil Type: AC
MKS3PIN5 AC120, MKS3PIN 5 AC120
