Datasheet G2RV-SL700 AC/DC24 - Omron Даташит Реле MODULE, SPDT, 24VAC/DC — Даташит
Наименование модели: G2RV-SL700 AC/DC24
![]() , Electromechanical Relay 24VDC 24VAC 1.84KΩ 6A SPDT Socket Slim Relay | |||
G2RVSL700ACDC24 Omron | 732 ₽ | ||
G2RVSL700ACDC24 Omron | 1 091 ₽ | ||
G2RVSL700ACDC24 Omron | 1 161 ₽ | ||
G2RV-SL700-AC/DC24 | по запросу |
Производитель: Omron
Описание: Реле MODULE, SPDT, 24VAC/DC
Slim Relay
G2RV
The World's First Industrial Slim Relay
· Large plug-in terminals for reliable connection.
· LED indicator and mechanical flag to check operation. · Transparent housing enables checking relay condition. · Slim outline to save space. · Push-in terminals and accessories for easy wiring.
Model Number Structure
- Coil Voltage VAC Nom: 24 VAC
- Coil Voltage VDC Nom: 24 V DC
- Contact Configuration: SPDT
- Внешняя длина / высота: 106.7 мм
- Внешняя ширина: 92.7 мм
- External Depth: 6.2 мм
- SVHC: No SVHC (18-Jun-2010)
- Contact Current AC Max: 6 А
- Contact Current DC Max: 6 А
- Contact Voltage AC Max: 250 VAC
- Contact Voltage DC Max: 30 V DC
- Mounting Type: Plug-In
- Number of Poles: 1
- Семейство: G2RV
- AC Coil Power: 0.5 VA
- Approval Bodies: VDE, CE
- Approval Category: UL Recognised
- Contact Material: AgSnin
- Contact Resistance: 100 МОм
- Current Rating: 6 А
- DC Coil Power: 300 мВт
- Dielectric Voltage Coil to Contact: 4000 VAC
- Dielectric Voltage Contact to Contact: 1000 VAC
- Insulation Resistance: 1000 МОм
- Insulation Voltage: 500 V DC
- Operating Time: 20 мс
- Release Time: 40 мс
- Switching Current AC Max: 6 А
- Switching Current DC Max: 6 А
- Switching Power Max: 180 Вт
- Switching Voltage AC: 400 VAC
- Switching Voltage DC: 125 V DC
- Terminal Type: Screw Terminals
- Рабочий диапазон температрур: -40°C ... 55°C
G2RVSL700 AC/DC24, G2RV SL700 AC/DC24
