Datasheet JS1-12V-F - Panasonic Даташит Реле, PCB, SPCO, 12 В DC — Даташит
Panasonic JS1-12V-F
Наименование модели: JS1-12V-F
21 предложений от 10 поставщиков
Реле Мощности, Power/Signal Relay, SPDT, Momentary, 0.03A (Coil), 12VDC (Coil), 360mW (Coil), 5A (Contact), 100VDC (Contact), DC Input, AC-DC Output, Through...
ИМЭК
Россия и страны ТС
JS1-12V-F SPDT, 250VAC, 30VDC, 10A
467 ₽
727GS
JS1-12V-F
Panasonic
от 1 758 ₽
JS1-12V-F
Panasonic
JS1-12V-F
Panasonic
Производитель: Panasonic
Описание: Реле, PCB, SPCO, 12 В DC
data sheetСкачать Data Sheet
JS
MINIATURE PC BOARD TYPE POWER RELAY
VDE
JS RELAYS
About Cd-free contacts We have introduced Cadmium free type products to reduce Environmental Hazardous Substances.
(The suffix "F" should be added to the part number) Please replace parts containing Cadmium with Cadmium-free products and evaluate them with your actual application before use because the life of a relay depends on the contact material and load.
  • Тип реле: Miniature
  • Coil Voltage VDC Nom: 12 В
  • Contact Current Max: 10 А
  • Contact Voltage AC Nom: 277 В
  • Contact Voltage DC Nom: 100 В
  • Coil Resistance: 400 Ом
  • Contact Configuration: SPCO
  • Coil Type: DC Coil
  • Coil Current: 30 мА
  • Nom Operating Power: 360 мВт
  • Relay Mounting: PC Board
  • Внешняя длина / высота: 22 мм
  • Внешняя ширина: 16.4 мм
  • External Depth: 16.4 мм
  • SVHC: No SVHC (18-Jun-2010)
  • Contact Current AC Max: 10 А
  • Contact Current DC Max: 5 А
  • Contact Voltage AC Max: 125 В
  • Contact Voltage DC Max: 30 В
  • Mounting Type: PCB
  • Number of Poles: 1
  • Семейство: JS
  • Approval Bodies: UL, CSA, TUV
  • Approval Category: UL Recognised
  • Coil Operating Lower Percent Limit: 70%
  • Coil Operating Upper Percent Limit: 130%
  • Contact Current Min: 6 А
  • Contact Material: Silver alloy
  • DC Coil Power: 360 мВт
  • Operating Time: 10 мс
  • PCB Hole Diameter: 1.3 мм
  • Release Time: 10 мс
  • Switch Current Max: 10 А
  • Switching Voltage AC / DC Min: 277 VAC
  • Рабочий диапазон температрур: -40°C ... 70°C
JS112VF, JS1 12V F
На английском языке: Datasheet JS1-12V-F - Panasonic RELAY, PCB, SPCO, 12 V DC
