Datasheet S4-5VDC - Panasonic Даташит Реле, PCB, 4PNO, 5 В DC — Даташит
Panasonic S4-5VDC
Наименование модели: S4-5VDC
Реле Мощности, General Purpose Relay, S Series, Power, Non Latching, 4PST-NO, 5VDC, 4A
S4-5VDC
Panasonic
934 ₽
S4-5VDC
Panasonic
1 512 ₽
Производитель: Panasonic
Описание: Реле, PCB, 4PNO, 5 В DC
data sheetСкачать Data Sheet
S
4 A CAPACITY, THE VARIETY OF CONTACT ARRANGEMENTS FEATURES
28.0 1.102 12.0 .472 10.4 .409
S RELAYS
· Wide switching range From 100µA 100 mV DC to 4 A 250 V AC · Low thermal electromotive force Approx.
3 µV · Dual-In-Line packaging arrangement
Каталог производителяКаталог производителя
Short Form
Relays
09/2007
Panasonic Relay Technology Innovation across the board.
Telecommunications, machine construction, measurement and control systems, automotive electronics, building security and installation ­ today there is virtually no branch of human activity that can exist without using modern relays. Panasonic Electric Works is able to meet both simple or complex demands from its vast range of sophisticated, economic switching technologies by offering the relay most appropriate to solving the specific application. ture relays for the new generation of surface mounting, automated assembly processes. In addition to electromechanical SMD types such as TQ, TX, GN, GQ and CP series, we have made significant developments in the rapidly expanding field of SSR and PhotoMOS relays.
  • Тип реле: Power
  • Coil Voltage VDC Nom: 5 В
  • Contact Current Max: 4 А
  • Contact Voltage AC Nom: 250 В
  • Contact Voltage DC Nom: 30 В
  • Coil Resistance: 130 Ом
  • Contact Configuration: 4PNO
  • Coil Type: DC Coil, Monostable
  • Coil Current: 38.5 мА
  • Nom Operating Power: 192 мВт
  • Relay Mounting: PC Board
  • Внешняя длина / высота: 28.4 мм
  • Внешняя ширина: 12.5 мм
  • External Depth: 10.2 мм
  • Contact Current AC Max: 4 А
  • Contact Current DC Max: 3 А
  • Contact Voltage AC Max: 250 В
  • Contact Voltage DC Max: 30 В
  • Mounting Type: PCB
  • Number of Poles: 4
  • Семейство: S
  • Тип: Single side stable
  • Approval Bodies: CSA
  • Approval Category: UL Recognised
  • Coil Operating Lower Percent Limit: 65%
  • Coil Operating Upper Percent Limit: 140%
  • Contact Current Min: 100ВµA
  • Contact Material: Silver alloy
  • Contact Plating: Gold clad
  • Contact Resistance: 50 МОм
  • Contact Style: 4 Form А
  • DC Coil Power: 192 мВт
  • Dielectric Voltage Coil to Contact: 1500 VAC
  • Рабочий диапазон температрур: -55°C ... 65°C
S45VDC, S4 5VDC
На английском языке: Datasheet S4-5VDC - Panasonic RELAY, PCB, 4PNO, 5 V DC
