Datasheet TXS2-4.5V - Panasonic Даташит Реле, PCB, DPDT, 4.5 В DC — Даташит
Panasonic TXS2-4.5V
Наименование модели: TXS2-4.5V
28 предложений от 15 поставщиков
Сигнальное реле, 4.5 В DC, DPDT, 1 А, Серия TX-S, Сквозное Отверстие, Без Защелки
TXS2-4.5V-1
Panasonic
91 ₽
TXS2-4.5V-1
Panasonic
222 ₽
TXS2-4.5V
Panasonic
от 476 ₽
TXS2-4.5V
Panasonic
от 763 ₽
Производитель: Panasonic
Описание: Реле, PCB, DPDT, 4.5 В DC
data sheetСкачать Data Sheet
TX-S
TESTING
New pin layout (LT type) added.
Ultra high sensitivity realized at 50 mW nominal operating power
3. High contact reliability High contact reliability is achieved by the use of gold-clad twin crossbar contacts, low-gas formation materials, mold sealing the coil section, and by controlling organic gas in the coil. *We also offer a range of products with AgPd contacts suitable for use in low level load analog circuits (Max. 10V DC 10 mA). *SX relays designed for low level loads are also available. 4. Outstanding surge resistance. Surge breakdown voltage between open contacts: 1,500 V 10Ч160 µsec. (FCC part 68) Surge breakdown voltage between contact and coil: 2,500 V 2Ч10 µsec. (Telcordia) 5. Low thermal electromotive force (approx. 0.3 µV) The structure of the mold-sealed body block of the coil section achieves nominal operating power of 50 mW and high sensitivity, along with low thermal electromotive force, reduced to approximately 0.3 µV.
TX-S RELAYS
  • Тип реле: General Purpose
  • Coil Voltage VDC Nom: 4.5 В
  • Contact Current Max: 1 А
  • Contact Voltage DC Nom: 30 В
  • Coil Resistance: 405 Ом
  • Contact Configuration: DPDT
  • Coil Type: DC Coil, Monostable
  • Coil Current: 11.1 мА
  • Nom Operating Power: 50 мВт
  • Relay Mounting: PC Board
  • Внешняя длина / высота: 8.2 мм
  • Внешняя ширина: 15 мм
  • External Depth: 7.4 мм
  • SVHC: No SVHC (18-Jun-2010)
  • Contact Current DC Max: 1 А
  • Contact Voltage DC Max: 110 В
  • Mounting Type: PCB
  • Number of Poles: 2
  • Семейство: TX-S
TXS24.5V, TXS2 4.5V
На английском языке: Datasheet TXS2-4.5V - Panasonic RELAY, PCB, DPDT, 4.5 V DC
