Datasheet JS1-12V - Panasonic Даташит POWER Реле, SPDT, 12 В DC, 10 А, PC BOARD — Даташит
Наименование модели: JS1-12V
![]() 23 предложений от 14 поставщиков Реле Мощности, Power/Signal Relay, SPDT, Momentary, 0.03A (Coil), 12VDC (Coil), 360mW (Coil), 5A (Contact), 100VDC (Contact), DC Input, AC-DC Output, Through... | |||
JS1-12V-F Panasonic | 73 ₽ | ||
JS1-12V Panasonic | от 275 ₽ | ||
JS1-12V-Y1-F Panasonic | по запросу | ||
JS1-12V-TV Panasonic | по запросу |
Производитель: Panasonic
Описание: POWER Реле, SPDT, 12 В DC, 10 А, PC BOARD
JS
MINIATURE PC BOARD TYPE POWER RELAY
VDE
JS RELAYS
About Cd-free contacts We have introduced Cadmium free type products to reduce Environmental Hazardous Substances.
(The suffix "F" should be added to the part number) Please replace parts containing Cadmium with Cadmium-free products and evaluate them with your actual application before use because the life of a relay depends on the contact material and load.
- Approval Bodies: UL & CSA, TUV
- Configuration, contact: SPCO
- Current, contact AC max: 10 А
- Current, switch max: 10 А
- Depth, external: 16.4 мм
- Length / Height, external: 22 мм
- Power, coil DC: 360 мВт
- Resistance, coil: 400R
- Temperature, operating (a) max: 70°C
- Temperature, operating (a) min: -40°C
- Voltage, coil DC nom: 12 В
- Voltage, contact AC max: 125 В
- Width, external: 16.4 мм
- Coil operating lower percent limit: 70%
- Coil operating upper percent limit: 130%
- Current, contact min: 6 А @ 277 В ac
- Diameter, PCB hole: 1.3 мм
- Material, contact: Silver alloy
- Time, operating: 10 мс
- Time, release: 10 мс
- Voltage, switching AC/DC min: 277 В ac
JS112V, JS1 12V
