Компактное аудиорешение Nuvoton NSP2340BA24E
Datasheet SSU-MR-201/C/R - Space Age Electronics Даташит Control Relay — Даташит
Space Age Electronics SSU-MR-201/C/R
Наименование модели: SSU-MR-201/C/R
Производитель: Space Age Electronics
Описание: Control Relay
data sheetСкачать Data Sheet
MR-100 & MR-200 Series Relays
MR1 MR2
The MR Series Multi-voltage Control Relays offer SPDT or DPDT 10 Amp resistive contacts which may be operated by one of four input control voltages.
A single relay may be energized from a voltage source of 24VDC, 24VAC, 120VAC or 230VAC by wiring to appropriate input terminals. Each relay position contains a red LED which indicates the relay coil is energized. Relays may be "snapped apart" from a standard 4 module assembly and used independently. These devices are ideal for applications where local contacts are required for system status, remote contacts for control of electrical loads and general purpose switching. They are suitable for use with HVAC, temperature control, fire alarm, security, energy management and lighting control systems.
Standard Features:
  • Coil Voltage VAC Nom: 230 В
  • Coil Voltage VDC Nom: 24 В
  • Contact Current Max: 7 А
  • Contact Voltage AC Nom: 230 В
  • Contact Voltage DC Nom: 28 В
  • Contacts: DPDT
  • Coil Type: AC / DC
  • Relay Mounting: Panel
  • External Height: 130 мм
SSUMR201/C/R, SSU MR 201/C/R
На английском языке: Datasheet SSU-MR-201/C/R - Space Age Electronics Control Relay
Политика конфиденциальности
