Datasheet DS4E-ML2-DC24V - Panasonic Даташит PCB Реле, CONTACTS 4PDT — Даташит
Наименование модели: DS4E-ML2-DC24V
7 предложений от 6 поставщиков Реле слабых сигналов - для печатного монтажа 2A 24VDC 4PDT 2 COIL LATCHING | |||
DS4E-ML2-DC24V Panasonic | от 804 ₽ | ||
DS4E-ML2-DC24V Panasonic | по запросу | ||
Производитель: Panasonic
Описание: PCB Реле, CONTACTS 4PDT
DS
HIGHLY SENSITIVE 1500 V FCC SURGE BREAKDOWN VOLTAGE MINIATURE RELAY
DS RELAYS
5.
Polarized magnetic circuits realize resistance to shock and vibration High-performance polarized magnetic circuits that utilize the energy of permanent magnets have made it possible to create relays with strong resistance to shock and vibration. 6. DIL terminal array enables use of IC sockets 7. Widening scope of application with multicontact latching In addition to single side stable types, you can take advantage of the memory of functions of convenient 1 coil or 2 coil latching relays.
FEATURES
- Coil Voltage VDC Nom: 24 В
- Coil Resistance: 1.6 кОм
- Contact Configuration: 4PDT
- Внешняя длина / высота: 9.8 мм
- Внешняя ширина: 35.24 мм
- External Depth: 9.9 мм
- SVHC: No SVHC (18-Jun-2010)
- Contact Current AC Max: 2 А
- Contact Current DC Max: 2 А
- Contact Voltage AC Max: 250 В
- Contact Voltage DC Max: 220 В
- Mounting Type: PCB
- Number of Poles: 4
- Семейство: DS
DS4EML2DC24V, DS4E ML2 DC24V
