Datasheet KUP-11A15-240 - Tyco Даташит POWER Реле, DPDT, 240 VAC, 10 А, PLUG IN — Даташит
Tyco KUP-11A15-240
Наименование модели: KUP-11A15-240
19 предложений от 12 поставщиков
Реле Мощности, Electromechanical Relay 240VAC 9.11KΩ 10A DPDT (( 38.89mm 35.71mm 55.55mm)) Socket Industrial Relay
KUP-11A15-240
1 423 ₽
Элитан
KUP-11A15-240
Tyco
2 685 ₽
KUP11A15240
TradeElectronics
KUP-11A15-240
Производитель: Tyco
Описание: POWER Реле, DPDT, 240 VAC, 10 А, PLUG IN
data sheetСкачать Data Sheet
KU series
KUP Enclosed Relay KUIP VDE 8mm Coil to Contacts KUGP VDE 8mm 3mm Gap Coil to Contacts KUEP 10 Amp 150VDC Load Switching KUMP 15 Amp 277VAC
File E22575 File LR15734 0435 Registration 1792 (KUIP) 0435 Registration 1792 (KUGP) License 81.12102.01
Features
· AC coils: 6-240VAC, 50/60 Hz.
DC: 6-110VDC. · Contact arrangement up to 4PDT. · Wide selection of termination and mounting styles. · PC terminals available. · Push to test button and indicator lamps. · KUEP incorporates a blow out magnet for high voltage DC switching. · KUIP/KUGP are VDE approved. · Complete line of sockets and DIN rail. · Class B coil insulation.
  • Тип реле: General Purpose
  • Coil Voltage VAC Nom: 240 В
  • Contact Current Max: 10 А
  • Contact Voltage AC Nom: 240 В
  • Contact Voltage DC Nom: 28 В
  • Coil Resistance: 9110 Ом
  • Contacts: DPDT
KUP11A15240, KUP 11A15 240
На английском языке: Datasheet KUP-11A15-240 - Tyco POWER RELAY, DPDT, 240 VAC, 10 A, PLUG IN
