Datasheet 8530661001 - Weidmuller Даташит DIN Mount Relay — Даташит
Weidmuller 8530661001
Наименование модели: 8530661001
8530661001
Weidmuller
Weidmuller
Weidmuller
Производитель: Weidmuller
Описание: DIN Mount Relay
data sheetСкачать Data Sheet
Product catalogue | Electronics | Relays | PLUGSERIES | 2 changeover contacts
General ordering data Order No.
Part designation Version EAN Input Rated control voltage Pull-in (sparkover) / drop-out voltage AC coil Rated current AC Power rating Status indicator Output Continuous current Inrush current Max. switching current Max. switching frequency at rated load Max. switching power Max. switching voltage AC Min. switching power Sparkover time / Drop-out time Switch-off delay Switch-on delay Contact data Number of contacts Contact base material Mechanical service life Rated data Climate Connection system DIN Rail compatibility
8530661001 PRS 120Vac LD 2CO Relays, 2 CO contact, 120 V AC ±10% , 2 x 8 A, Screw connection 4032248216314 120 V AC ±10% 53 V / 49 V 9.1 mA 1.1 VA Green LED 2x8A 2x8A 16 A 0.1 Hz 2x2 kVA 250 V 10 V / 100 mA 7.8 ms / 41.5 ms <45ms 9ms 2 AgNi 90/10 6 5*10 switching cycles 40°C/93% rel. humidity, no condensation Screw connection TS 35
-1-
  • Тип реле: General Purpose
  • Coil Voltage VAC Nom: 120 В
  • Contact Current Max: 16 А
  • Contact Voltage AC Nom: 250 В
  • Contacts: 2CO
  • Coil Type: AC
  • Coil Current: 9.1 мА
  • Nom Operating Power: 1.1 VA
  • Способ монтажа: DIN Rail
На английском языке: Datasheet 8530661001 - Weidmuller DIN Mount Relay
