Datasheet BSM10GD120DN2 - Infineon Даташит IGBT MODULE, 1200 В, ECONOPACK3 — Даташит
Наименование модели: BSM10GD120DN2
 Купить BSM10GD120DN2 на РадиоЛоцман.Цены — от 2 162 до 24 468 ₽18 предложений от 17 поставщиков БТИЗ массив и модульный транзистор, Three Phase Full Bridge, 15 А, 3.2 В, 80 Вт, 125 °C, EconoPACK  | |||
| BSM10GD120DN2BOSA1 | 5 042 ₽ | ||
| BSM10GD120DN2 | 9 159 ₽ | ||
| BSM10GD120DN2BOSA1 Infineon  | от 24 468 ₽ | ||
| BSM10GD120DN2E Infineon  | по запросу | ||
Производитель: Infineon
Описание: IGBT MODULE, 1200 В, ECONOPACK3
BSM 10 GD 120 DN2
IGBT Power Module
· Power module · 3-phase full-bridge · Including fast free-wheel diodes · Package with insulated metal base plate Type BSM 10 GD 120 DN2 BSM 10 GD120DN2E3224 Maximum Ratings Parameter Collector-emitter voltage Collector-gate voltage RGE = 20 k Gate-emitter voltage DC collector current TC = 25 °C TC = 80 °C Pulsed collector current, tp = 1 ms TC = 25 °C TC = 80 °C Power dissipation per IGBT TC = 25 °C Chip temperature Storage temperature Thermal resistance, chip case Diode thermal resistance, chip case Insulation test voltage, t = 1min.
Creepage distance Clearance DIN humidity category, DIN 40 040 IEC climatic category, DIN IEC 68-1 Tj Tstg RthJC RthJCD Vis Ptot 80 + 150 -40 ... + 125  1.52 2 2500 16 11 F 40 / 125 / 56 sec Vac mm K/W °C ICpuls 30 20 W VGE IC 15 10 Symbol VCE VCGR 1200 ± 20 A Values 1200 Unit V VCE IC Package ECONOPACK 2 ECONOPACK 2K Ordering Code C67076-A2513-A67 C67070-A2513-A67
1200V 15A 1200V 15A
1
- Module Configuration: Six
 - DC Collector Current: 15 А
 - Collector Emitter Voltage Vces: 3.2 В
 - Power Dissipation Max: 80 Вт
 - Collector Emitter Voltage V(br)ceo: 1.2kV
 - Рабочий диапазон температрур: -40°C ... +125°C
 - Корпус транзистора: Econopack 3
 - Количество выводов: 17
 - Количество транзисторов: 6
 - Тип корпуса: Econopack 3
 - Способ монтажа: Solder
 - Тип транзистора:
 - Current Ic Continuous a Max: 15 А
 - Current Temperature: 80°C
 - Power Dissipation: 80 Вт
 - Power Dissipation Pd: 80 Вт
 - Pulsed Current Icm: 30 А
 - Voltage Vce Sat Typ: 2.7 В
 - Voltage Vces: 1.2kV
