Datasheet E-TDA2003V - STMicroelectronics Даташит усилитель, аудио, 10 Вт, 2003, PENTAWATT-5 — Даташит
STMicroelectronics E-TDA2003V
Наименование модели: E-TDA2003V
Описание: Усилитель, аудио, 10 Вт, 2003, PENTAWATT-5
data sheetСкачать Data Sheet
TDA2003
10W CAR RADIO AUDIO AMPLIFIER
DESCRIPTION The TDA 2003 has improved performance with the same pin configuration as the TDA 2002.
The additional features of TDA 2002, very low number of external components, ease of assembly, space and cost saving, are maintained. The device provides a high output current capability (up to 3.5A) very low harmonic and cross-over distortion. Completely safe operation is guaranteed due to protection against DC and AC short circuit between all pins and ground, thermal over-range, load dump voltage surge up to 40V and fortuitous open ground. ABSOLUTE MAXIMUM RATINGS
Symbol VS VS VS IO IO Ptot Tstg, Tj Parameter Peak supply voltage (50ms) DC supply voltage Operating supply voltage Output peak current (repetitive) Output peak current (non repetitive) Power dissipation at Tcase = 90°C Storage and junction temeperature
  • Количество каналов: 1
  • Output Power: 10 Вт
  • Диапазон напряжения питания: 8 В ... 18 В
  • THD + N: 0.15% @ 4.5 Вт, 4 Ом, VDD=14.4V
  • Load Impedance: 1.6 Ом
  • Amplifier Case Style: TO-220
  • Количество выводов: 5
  • SVHC: No SVHC (18-Jun-2010)
  • Тип корпуса: Pentawatt
  • Amplifier Type: Power
  • Bandwidth: 0.015 МГц
  • Семейство: 2003
  • Маркировка: TDA2003V
  • IC Generic Number: 2003
  • Load Impedance Min: 1.6 Ом
  • Количество логических функций: 2003
  • Number of Amplifiers: 1
  • Рабочий диапазон температрур: -40°C ... +150°C
  • Operational Amplifier Features: Car Radio Power
  • Output Power Pout: 6 Вт @ 4 Ом
  • Power Rating RMS: 12 Вт
  • Supply Voltage + Nom: 12 В
ETDA2003V, E TDA2003V
На английском языке: Datasheet E-TDA2003V - STMicroelectronics AMP, AUDIO, 10 W, 2003, PENTAWATT-5
Политика конфиденциальности
