Datasheet HY2000 - ILP Electronics Даташит ИС, усилитель, POWER, , 30 Вт, 2000 — Даташит
Наименование модели: HY2000
| HY2000 | по запросу | ||
Производитель: ILP Electronics
Описание: ИС, усилитель, POWER, , 30 Вт, 2000
DATA SHEET HY2000 30 WATTS
The ILP HY2000 Power Amplifier is a fully encapsulated high quality power amplifier with Integral heatsink.
By selecting the appropiate mains transformer and the programming link on the PCB the amplifier can be used with 4 or 8 loads with the automatic adjustment of input sensitivity. Mounting can be achieved by the use of T-slots in the heatsink and the nuts and bolts provided.
TYPICAL SPECIFICATIONS
Parameter Output Power Frequency Response (-3dB) Total Harmonic Distortion @ 1kHz Signal to Noise Ratio (DIN AUDIO) Slew Rate typical Rise Time Input Sensitivity Input Impedance Damping Factor(8 @ 100Hz) Load Impedance (programmable) Maximum D.C. rails (8 load) Size Width x Height x Extrusion Cut Weight Value 40W rms. Max 15Hz - 50kHz 0.005% 100dB 10V/µS 5µS 500mV rms. 100K >400 4 or 8 ±30V 76x75x30mm 170g
- Количество каналов: 1
- Output Power: 40 Вт
- THD + N: 0.005%
- Load Impedance: 4 Ом
- Количество выводов: 7
- Тип корпуса: Rectangular
- Amplifier Type: Power
- Bandwidth: 50 кГц
- Семейство: 2000
- Damping Factor: 400
- Dimensions: 30 x 76
- Frequency Response: 15 Гц ... 50 кГц
- IC Generic Number: 2000
- Input Impedance: 100 кОм
- Input Offset Voltage Max: 500mV
- Load A Impedance: 4 Ом
- Load B Impedance: 8 Ом
- Load Impedance Min: 4 Ом
- Количество логических функций: 2000
- Loudspeaker Fuse Current @ 4ohm: 2 А
- Loudspeaker Fuse Current @ 8ohm: 1.5 А
- Number of Amplifiers: 1
- Output Power Pout: 30 Вт
- Power Rating RMS: 30 Вт
- Signal to Noise Ratio: 100 дБ
- Slew Rate: 10
- Supply Voltage + Nom: 30 В
- Supply Voltage - Nom: 30 В
- Напряжение питания максимальное: 30 В
- Способ монтажа: Through Hole
- Total Harmonic Distortion: 0.005%
- Рабочий диапазон температрур: 0°C ... 85°C
