Datasheet HY2001 - ILP Electronics Даташит ИС, усилитель, POWER, + PSU, 30 Вт, 2001 — Даташит
ILP Electronics HY2001
Наименование модели: HY2001
Производитель: ILP Electronics
Описание: ИС, усилитель, POWER, + PSU, 30 Вт, 2001
data sheetСкачать Data Sheet
DATA SHEET HY2001 30 WATTS
The ILP HY2001 Power Amplifier is a fully encapsulated high quality power amplifier with Integral Power Supply and heatsink.
By selecting the appropiate mains transformer and the programming link on the PCB the amplifier can be used with 4 or 8 loads with the automatic adjustment of input sensitivity. Mounting can be achieved by the use of T-slots in the heatsink and the nuts and bolts provided. TYPICAL SPECIFICATIONS
Parameter Output Power Frequency Response (-3dB) Total Harmonic Distortion @ 1kHz Signal to Noise Ratio (DIN AUDIO) Slew Rate typical Rise Time Input Sensitivity Input Impedance Damping Factor(8 @ 100Hz) Load Impedance (programmable) Maximum D.C. rails (8 load) Size Width x Height x Extrusion Cut Weight Value 40W rms. Max 15Hz - 50kHz 0.005% 100dB 10V/µS 5µS 500mV rms. 100K >400 4 or 8 ±30V 76x100x30mm 200g
FEATURES Programmable 4 or 8 operation Integral Power Supply Anti-thump Circuitry Integral heatsink Thermal Protection PTH
  • Количество каналов: 1
  • Output Power: 40 Вт
  • THD + N: 0.005%
  • Load Impedance: 4 Ом
  • Количество выводов: 8
  • Тип корпуса: Rectangular
  • Amplifier Type: Power
  • Bandwidth: 50 кГц
  • Семейство: 2001
  • Damping Factor: 400
  • Dimensions: 30 x 76
  • Frequency Response: 15 Гц ... 50 кГц
  • IC Generic Number: 2001
  • Input Impedance: 100 кОм
  • Input Offset Voltage Max: 500mV
  • Input Voltage: 500mV
  • Load A Impedance: 4 Ом
  • Load B Impedance: 8 Ом
  • Load Impedance Min: 4 Ом
  • Количество логических функций: 2001
  • Loudspeaker Fuse Current @ 4ohm: 2 А
  • Loudspeaker Fuse Current @ 8ohm: 1.5 А
  • Number of Amplifiers: 1
  • Output Power Pout: 30 Вт
  • Power Rating RMS: 30 Вт
  • Signal to Noise Ratio: 100 дБ
  • Slew Rate: 10
  • Supply Voltage + Nom: 20 В
  • Supply Voltage - Nom: 20 VAC
  • Напряжение питания максимальное: 30 В
  • Total Harmonic Distortion: 0.005%
  • Рабочий диапазон температрур: 0°C ... 85°C
На английском языке: Datasheet HY2001 - ILP Electronics IC, AMP, POWER, + PSU, 30 W, 2001
