Datasheet HY2002 - ILP Electronics Даташит ИС, усилитель, POWER, , 60 Вт, 2002 — Даташит
ILP Electronics HY2002
Наименование модели: HY2002
МосЧип
HY2002по запросу
Производитель: ILP Electronics
Описание: ИС, усилитель, POWER, , 60 Вт, 2002
data sheetСкачать Data Sheet
DATA SHEET HY2002 60 WATTS
The ILP HY2002 Power Amplifier is a fully encapsulated high quality power amplifier with Integral heatsink.
By selecting the appropiate mains transformer and the programming link on the PCB the amplifier can be used with 4 or 8 loads with the automatic adjustment of input sensitivity. Mounting can be achieved by the use of T-slots in the heatsink and the nuts and bolts provided.
TYPICAL SPECIFICATIONS
Parameter Output Power Frequency Response (-3dB) Total Harmonic Distortion @ 1kHz Signal to Noise Ratio (DIN AUDIO) Slew Rate typical Rise Time Input Sensitivity Input Impedance Damping Factor(8 @ 100Hz) Load Impedance (programmable) Maximum D.C. rails (8 load) Size Width x Height x Extrusion Cut Weight Value 75W rms. Max 15Hz - 50kHz 0.005% 100dB 15V/µS 5µS 500mV rms. 100K >400 4 or 8 ±40V 120x85x30mm 295g
  • Количество каналов: 1
  • Output Power: 75 Вт
  • THD + N: 0.005%
  • Load Impedance: 4 Ом
  • Количество выводов: 6
  • Тип корпуса: Rectangular
  • Amplifier Type: Power
  • Bandwidth: 50 кГц
  • Семейство: 2002
  • Damping Factor: 400
  • Dimensions: 30 x 120
  • Frequency Response: 15 Гц ... 50 кГц
  • IC Generic Number: 2002
  • Input Impedance: 100 кОм
  • Input Offset Voltage Max: 500mV
  • Input Voltage: 500mV
  • Load A Impedance: 4 Ом
  • Load B Impedance: 8 Ом
  • Load Impedance Min: 4 Ом
  • Количество логических функций: 2002
  • Loudspeaker Fuse Current @ 4ohm: 2.5 А
  • Loudspeaker Fuse Current @ 8ohm: 2 А
  • Number of Amplifiers: 1
  • Output Power Pout: 60 Вт
  • Power Rating RMS: 60 Вт
  • Signal to Noise Ratio: 100 дБ
  • Slew Rate: 15
  • Supply Voltage + Nom: 40 В
  • Supply Voltage - Nom: 40 В
  • Напряжение питания максимальное: 40 В
  • Total Harmonic Distortion: 0.005%
  • Рабочий диапазон температрур: 0°C ... 85°C
На английском языке: Datasheet HY2002 - ILP Electronics IC, AMP, POWER, , 60 W, 2002
