Datasheet HY2004 - ILP Electronics Даташит ИС, усилитель, POWER, , 120 Вт, 2004 — Даташит
ILP Electronics HY2004
Наименование модели: HY2004
HY-2004A-802
ABC020004B14-YLY-R HY2004A-207
HY2004
Производитель: ILP Electronics
Описание: ИС, усилитель, POWER, , 120 Вт, 2004
data sheetСкачать Data Sheet
DATA SHEET HY2004 120 WATTS
The ILP HY2004 Power Amplifier is a fully encapsulated high quality power amplifier with Integral heatsink.
By selecting the appropiate mains transformer and programming link the amplifier can be used with 4 or 8 loads with the automatic adjustment of input sensitivity. Mounting can be achieved by the use of T-slots in the heatsink and the nuts and bolts provided.
TYPICAL SPECIFICATIONS
Parameter Output Power Frequency Response (-3dB) Total Harmonic Distortion @ 1kHz Signal to Noise Ratio (DIN AUDIO) Slew Rate typical Rise Time Input Sensitivity Input Impedance Damping Factor(8 @ 100Hz) Load Impedance (programmable) Maximum D.C. rails (8 load) Size Width x Height x Extrusion Cut Weight Value 150W rms. Max 15Hz - 50kHz 0.005% 100dB 20V/µS 5µS 500mV rms. 100K >400 4 or 8 ±55V 120x75x80mm 835g
  • Количество каналов: 1
  • Output Power: 150 Вт
  • THD + N: 0.005%
  • Load Impedance: 4 Ом
  • Количество выводов: 8
  • Тип корпуса: Rectangular
  • Amplifier Type: Power
  • Bandwidth: 50 кГц
  • Семейство: 2004
  • Damping Factor: 400
  • Dimensions: 80 x 120
  • Frequency Response: 15 Гц ... 50 кГц
  • IC Generic Number: 2004
  • Input Impedance: 100 кОм
  • Input Offset Voltage Max: 500mV
  • Input Voltage: 500mV
  • Load A Impedance: 4 Ом
  • Load B Impedance: 8 Ом
  • Load Impedance Min: 4 Ом
  • Количество логических функций: 2004
  • Loudspeaker Fuse Current @ 4ohm: 3.15 А
  • Loudspeaker Fuse Current @ 8ohm: 2.5 А
  • Number of Amplifiers: 1
  • Output Power Pout: 120 Вт
  • Power Rating RMS: 120 Вт
  • Signal to Noise Ratio: 100 дБ
  • Slew Rate: 20
  • Supply Voltage + Nom: 55 В
  • Supply Voltage - Nom: 55 В
  • Напряжение питания максимальное: 55 В
  • Total Harmonic Distortion: 0.005%
  • Рабочий диапазон температрур: 0°C ... 85°C
На английском языке: Datasheet HY2004 - ILP Electronics IC, AMP, POWER, , 120 W, 2004
