Datasheet HY2005 - ILP Electronics Даташит ИС, усилитель, POWER, + PSU, 120 Вт, 2005 — Даташит
ILP Electronics HY2005
Наименование модели: HY2005
Производитель: ILP Electronics
Описание: ИС, усилитель, POWER, + PSU, 120 Вт, 2005
data sheetСкачать Data Sheet
DATA SHEET HY2005 120 WATTS
The ILP HY2005 Power Amplifier is a fully encapsulated high quality power amplifier with Integral Power Supply and heatsink.
By selecting the appropiate mains transformer and the programming link on the PCB the amplifier can be used with 4 or 8 loads with the automatic adjustment of input sensitivity. Mounting can be achieved by the use of T-slots in the heatsink and the nuts and bolts provided.
TYPICAL SPECIFICATIONS
Parameter Output Power Frequency Response (-3dB) Total Harmonic Distortion @ 1kHz Signal to Noise Ratio (DIN AUDIO) Slew Rate typical Rise Time Input Sensitivity Input Impedance Damping Factor(8 @ 100Hz) Load Impedance (programmable) Maximum D.C. rails (8 load) Size Width x Height x Extrusion Cut Weight Value 150W rms. Max 15Hz - 50kHz 0.005% 100dB 20V/µS 5µS 500mV rms. 100K >400 4 or 8 ±55V 120x75x80mm 950g
  • Количество каналов: 1
  • Output Power: 150 Вт
  • THD + N: 0.005%
  • Load Impedance: 4 Ом
  • Количество выводов: 11
  • Тип корпуса: Rectangular
  • Amplifier Type: Power
  • Bandwidth: 50 кГц
  • Семейство: 2005
  • Damping Factor: 400
  • Dimensions: 80 x 120
  • Frequency Response: 15 Гц ... 50 кГц
  • IC Generic Number: 2005
  • Input Impedance: 100 кОм
  • Input Offset Voltage Max: 500mV
  • Input Voltage: 500mV
  • Load A Impedance: 4 Ом
  • Load B Impedance: 8 Ом
  • Load Impedance Min: 4 Ом
  • Количество логических функций: 2005
  • Loudspeaker Fuse Current @ 4ohm: 3.15 А
  • Loudspeaker Fuse Current @ 8ohm: 2.5 А
  • Number of Amplifiers: 1
  • Output Power Pout: 120 Вт
  • Power Rating RMS: 120 Вт
  • Signal to Noise Ratio: 100 дБ
  • Slew Rate: 20
  • Supply Voltage + Nom: 40 В
  • Supply Voltage - Nom: 40 VAC
  • Напряжение питания максимальное: 55 В
  • Total Harmonic Distortion: 0.005%
  • Рабочий диапазон температрур: 0°C ... 85°C
На английском языке: Datasheet HY2005 - ILP Electronics IC, AMP, POWER, + PSU, 120 W, 2005
