Datasheet LM1877M-9/NOPB - National Semiconductor Даташит ИС, усилитель аудио POWER DUAL 14-SO — Даташит
Наименование модели: LM1877M-9/NOPB
![]() 25 предложений от 17 поставщиков Микросхема Усилитель звуковой частоты, TEXAS INSTRUMENTS LM1877M-9/NOPB Audio Power Amplifier, AB, 2Channel, 1.3W, 6V to 24V, SOIC, 14Pins | |||
LM1877M-9/NOPB Texas Instruments | от 242 ₽ | ||
LM1877M-9@NOPB Texas Instruments | по запросу | ||
LM1877M-9/NOPB Texas Instruments | по запросу | ||
Описание: ИС, усилитель аудио POWER DUAL 14-SO
LM1877 Dual Audio Power Amplifier
February 1995
General Description
The LM1877 is a monolithic dual power amplifier designed to deliver 2W/channel continuous into 8 loads.
The LM1877 is designed to operate with a low number of external components, and still provide flexibility for use in stereo phonographs, tape recorders and AM-FM stereo receivers, etc. Each power amplifier is biased from a common internal regulator to provide high power supply rejection, and output Q point centering. The LM1877 is internally compensated for all gains greater than 10. n n n n n Wide supply range, 6V24V Very low cross-over distortion Low audio band noise AC short circuit protected Internal thermal shutdown
- Amplifier Class: AB
- Количество каналов: 2
- Output Power: 1.3 Вт
- Диапазон напряжения питания: 6 В ... 24 В
- THD + N: 0.055% @ 1 Вт, 8 Ом, VS=20V
- Load Impedance: 8 Ом
- Amplifier Case Style: SOIC
- Количество выводов: 14
- SVHC: No SVHC (15-Dec-2010)
- Тип корпуса: SOIC
- Семейство: 1877
- Load Impedance Min: 8 Ом
- Рабочий диапазон температрур: 0°C ... +70°C
- Output Power Pout: 1.3 Вт
- Power Rating RMS: 2 Вт
- Способ монтажа: SMD
LM1877M9/NOPB, LM1877M 9/NOPB
