Datasheet LM3875TF/NOPB - National Semiconductor Даташит ИС, усилитель, аудио POWER, MONO — Даташит
Наименование модели: LM3875TF/NOPB
Купить LM3875TF/NOPB на РадиоЛоцман.Цены — от 273 до 732 ₽10 предложений от 10 поставщиков Микросхема Усилитель звуковой частоты, Audio Power Amplifier, AB, 1Channel, 56W, 20V to 84V, TO-220, 11Pins | |||
| LM3875TF/NOPB Texas Instruments | 273 ₽ | ||
| LM3875TF/NOPB Texas Instruments | 732 ₽ | ||
| LM3875TF/NOPB Texas Instruments | по запросу | ||
| LM3875TF/NOPB | по запросу | ||
Описание: ИС, усилитель, аудио POWER, MONO
LM3875 Overture Audio Power Amplifier Series High-Performance 56W Audio Power Amplifier
August 2000
LM3875 OvertureTM Audio Power Amplifier Series High-Performance 56W Audio Power Amplifier
General Description
The LM3875 is a high-performance audio power amplifier capable of delivering 56W of continuous average power to an 8 load with 0.1% THD+N from 20Hz to 20kHz.
The performance of the LM3875, utilizing its Self Peak Instantaneous Temperature (°Ke) (SPiKeTM) protection circuitry, puts it in a class above discrete and hybrid amplifiers by providing an inherently, dynamically protected Safe Operating Area (SOA). SPiKe protection means that these parts are completely safeguarded at the output against overvoltage, undervoltage, overloads, caused by shorts to the supplies, thermal runaway, and instantaneous temperature peaks. The LM3875 maintains an excellent signal-to-noise ratio of greater than 95dB(min) with a typical low noise floor of 2.0µV. It exhibits extremely low THD+N values o
- Amplifier Class: AB
- Количество каналов: 1
- Output Power: 56 Вт
- Диапазон напряжения питания: 20 В ... 84 В
- THD + N: 0.06% @ 40 Вт, 8 Ом, V=35V
- Load Impedance: 8 Ом
- Amplifier Case Style: TO-220
- Количество выводов: 11
- SVHC: No SVHC (15-Dec-2010)
- Тип корпуса: TO-220
- Bandwidth: 8 МГц
- Input Offset Voltage Max: 10mV
- Load Impedance Min: 8 Ом
- Рабочий диапазон температрур: -20°C ... +85°C
- Output Power Pout: 56 Вт
- Power Rating RMS: 56 Вт
- Slew Rate: 11 В/мкс
- Способ монтажа: Through Hole
