Datasheet LM3886TF - National Semiconductor Даташит усилитель, OVERTURE MUTE 68 Вт, 3886, TO-220 — Даташит
National Semiconductor LM3886TF
Наименование модели: LM3886TF
62 предложений от 29 поставщиков
Усилитель звуковой мощности, 68 Вт, B, 1 канал, 20В до 84В, TO-220, 11 вывод(-ов)
LM3886TF/NOPB
312 ₽
LM3886TF/NOPB
от 622 ₽
LM3886TF/NOPB
от 713 ₽
LM3886TF
Описание: Усилитель, OVERTURE MUTE 68 Вт, 3886, TO-220
data sheetСкачать Data Sheet
LM3886 Overture Audio Power Amplifier Series High-Performance 68W Audio Power Amplifier w/Mute
October 2003
LM3886 OvertureTM Audio Power Amplifier Series High-Performance 68W Audio Power Amplifier w/Mute
General Description
The LM3886 is a high-performance audio power amplifier capable of delivering 68W of continuous average power to a 4 load and 38W into 8 with 0.1% THD+N from 20Hz­20kHz.
The performance of the LM3886, utilizing its Self Peak Instantaneous Temperature (°Ke) (SPiKeTM) protection circuitry, puts it in a class above discrete and hybrid amplifiers by providing an inherently, dynamically protected Safe Operating Area (SOA). SPiKe protection means that these parts are completely safeguarded at the output against overvoltage, undervoltage, overloads, including shorts to the supplies, thermal runaway, and instantaneous temperature peaks. The LM3886 maintains an excellent signal-to-noise ratio of greater than 92dB with a typical low noise floor of 2.0µV. It exhibits extreme
  • Amplifier Class: B
  • Количество каналов: 1
  • Output Power: 68 Вт
  • Диапазон напряжения питания: 20 В ... 84 В
  • THD + N: 0.03% @ 30 Вт, 8 Ом, V=28V
  • Load Impedance: 8 Ом
  • Amplifier Case Style: TO-220
  • Количество выводов: 11
  • SVHC: No SVHC (15-Dec-2010)
  • Тип корпуса: TO-220
  • Amplifier Type: Power
  • Bandwidth: 3 МГц
  • Семейство: 3886
  • Маркировка: LM3886TF
  • IC Generic Number: 3886
  • Input Offset Voltage Max: 10mV
  • Load Impedance Min: 4 Ом
  • Количество логических функций: 3886
  • Number of Amplifiers: 1
  • Рабочий диапазон температрур: -20°C ... +85°C
  • Output Power Pout: 50 Вт @ 8 Ом
  • Power Rating RMS: 68 Вт
  • Slew Rate: 19
  • Supply Voltage + Nom: 20 В
  • Total Harmonic Distortion: 0.03%
На английском языке: Datasheet LM3886TF - National Semiconductor AMP, OVERTURE MUTE 68 W, 3886, TO-220
