Datasheet LM4562HA/NOPB - National Semiconductor Даташит OP усилитель аудио DUAL HF TO-99, POWERWISE — Даташит
National Semiconductor LM4562HA/NOPB
Наименование модели: LM4562HA/NOPB
Микросхема Операционный усилитель, TEXAS INSTRUMENTS LM4562HA/NOPB Operational Amplifier, 2 Amplifier, 20V/µs, ± 2.5V to ± 17V, TO-99, 8Pins
LM4562HA/NOPB
136 ₽
LM4562HA/NOPB
389 ₽
LM4562HA/NOPB
709 ₽
LM4562HA/NOPB
Описание: OP усилитель аудио DUAL HF TO-99, POWERWISE
data sheetСкачать Data Sheet
LM4562 Dual High Performance, High Fidelity Audio Operational Amplifier
October 2007
General Description
The LM4562 is part of the ultra-low distortion, low noise, high slew rate operational amplifier series optimized and fully specified for high performance, high fidelity applications.
Combining advanced leading-edge process technology with state-of-the-art circuit design, the LM4562 audio operational amplifiers deliver superior audio signal amplification for outstanding audio performance. The LM4562 combines extremely low voltage noise density (2.7nV/Hz) with vanishingly low THD+N (0.00003%) to easily satisfy the most demanding audio applications. To ensure that the most challenging loads are driven without compromise, the LM4562 has a high slew rate of ±20V/s and an output current capability of ±26mA. Further, dynamic range is maximized by an output stage that drives 2k loads to within 1V of either power suppl
Данные для моделированияДанные для моделирования
  • Amplifier Class: AB
  • Количество каналов: 2
  • Диапазон напряжения питания: ± 2.5 В ... ± 17 В
  • THD + N: 0.00003% @ 2 кОм, VS=± 15 В
  • Load Impedance: 2 кОм
  • Amplifier Case Style: TO-99
  • Количество выводов: 8
  • SVHC: No SVHC (15-Dec-2010)
  • Тип корпуса: TO-99
  • Семейство: 4562
  • Number of Amplifiers: 2
  • Рабочий диапазон температрур: -40°C ... +85°C
  • Slew Rate: 20 В/мкс
  • Gain Bandwidth: 55 МГц
  • Op Amp Type: Low Noise
На английском языке: Datasheet LM4562HA/NOPB - National Semiconductor OP AMP AUDIO DUAL HF TO-99, POWERWISE
