Datasheet LM4702CTA - National Semiconductor Даташит DRIVER аудио стерео, SMD, TO-220-15 — Даташит
National Semiconductor LM4702CTA
Наименование модели: LM4702CTA
19 предложений от 19 поставщиков
Микросхема Усилитель звуковой частоты, TEXAS INSTRUMENTS LM4702CTA Audio Power Amplifier, 2Channel, ± 20V to ± 75V, TO-220, 15Pins
LM4702CTA
38 ₽
LM4702CTA/NOPB
843 ₽
LM4702CTA
2 511 ₽
Рутоника
LM4702CTA/NOPB
Описание: DRIVER аудио стерео, SMD, TO-220-15
data sheetСкачать Data Sheet
LM4702 Stereo High Fidelity 200 Volt Driver with Mute
September 2006
LM4702 Audio Power Amplifier Series Stereo High Fidelity 200 Volt Driver with Mute
General Description
The LM4702 is a high fidelity audio power amplifier driver designed for demanding consumer and pro-audio applications.
Amplifier output power may be scaled by changing the supply voltage and number of output devices. The LM4702 is capable of delivering in excess of 300 watts per channel single ended into an 8 ohm load in the presence of 10% high line headroom and 20% supply regulation. The LM4702 includes thermal shut down circuitry that activates when the die temperature exceeds 150°C. The LM4702's mute function, when activated, mutes the input drive signal and forces the amplifier output to a quiescent state. The LM4702 is available in 3 grades that span a wide range of applications and performance levels. The LM4702C is targeted at high volume applications. The LM4702B includes a higher voltage rating along with
  • Количество каналов: 2
  • Диапазон напряжения питания: ± 20 В ... ± 75 В
  • THD + N: 0.005% @ VDD=75V
  • Load Impedance: 8 Ом
  • Amplifier Case Style: TO-220
  • Количество выводов: 15
  • SVHC: No SVHC (15-Dec-2010)
  • Тип корпуса: TO-220
  • Amplifier Type: Power
  • Семейство: 4702
  • Input Offset Voltage Max: 35mV
  • Load Impedance Min: 8 Ом
  • Number of Amplifiers: 1
  • Рабочий диапазон температрур: -20°C ... +75°C
  • Output Power Pout: 300 Вт @ 8 Ом
  • Power Rating RMS: 300 Вт
  • Slew Rate: 15
  • Supply Voltage + Nom: 75 В
Дополнительные аксессуары:
  • Fischer Elektronik - WLPG 02
На английском языке: Datasheet LM4702CTA - National Semiconductor DRIVER AUDIO STEREO, SMD, TO-220-15
