Datasheet LM4765T/NOPB - National Semiconductor Даташит ИС, аудио усилитель, DUAL, 30 Вт, TO-220-15 — Даташит
National Semiconductor LM4765T/NOPB
Наименование модели: LM4765T/NOPB
17 предложений от 17 поставщиков
Микросхема Усилитель звуковой частоты, TEXAS INSTRUMENTS LM4765T/NOPB Audio Power Amplifier, AB, 2Channel, 30W, 20V to 64V, TO-220, 15Pins
LM4765T/NOPB
308 ₽
Эиком
LM4765T/NOPB
746 ₽
Рутоника
LM4765T/NOPB
LM4765T/NOPB
Описание: ИС, аудио усилитель, DUAL, 30 Вт, TO-220-15
data sheetСкачать Data Sheet
LM4765 OvertureTM Audio Power Amplifier Series Dual 30W Audio Power Amplifier with Mute and Standby Modes
August 2000
General Description
The LM4765 is a stereo audio amplifier capable of delivering typically 30W per channel of continuous average output power into an 8 load with less than 0.1% THD+N.
Each amplifier has an independent smooth transition fadein/out mute and a power conserving standby mode which can be controlled by external logic. The performance of the LM4765, utilizing its Self Peak Instantaneous Temperature (°Ke) (SPiKeTM) protection circuitry, places it in a class above discrete and hybrid amplifiers by providing an inherently, dynamically protected Safe Operating Area (SOA). SPiKe protection means that these parts are safeguarded at the output against overvoltage, undervoltage, overloads, including thermal runaway and instantaneous temperature peaks.
  • Amplifier Class: AB
  • Количество каналов: 2
  • Output Power: 30 Вт
  • Диапазон напряжения питания: 20 В ... 64 В
  • THD + N: 0.08% @ 30 Вт, 8 Ом, VCC=28V
  • Load Impedance: 8 Ом
  • Amplifier Case Style: TO-220
  • Количество выводов: 15
  • SVHC: No SVHC (15-Dec-2010)
  • Тип корпуса: TO-220
  • Семейство: 4765
  • Load Impedance Min: 8 Ом
  • Рабочий диапазон температрур: -20°C ... +85°C
  • Output Power Pout: 30 Вт
  • Power Rating RMS: 30 Вт
На английском языке: Datasheet LM4765T/NOPB - National Semiconductor IC, AUDIO AMP, DUAL, 30 W, TO-220-15
