Линейка продуктов KEEN SIDE
Datasheet LM4766T - National Semiconductor Даташит ИС, усилитель, DUAL 40 Вт, 4766, TO-220-15 — Даташит
National Semiconductor LM4766T
Наименование модели: LM4766T
53 предложений от 28 поставщиков
Интегральные микросхемы Линейные микросхемы - Усилители - Звуковые
LM4766T
36 ₽
LM4766T/LF15
66 ₽
LM4766T
91 ₽
Триема
LM4766T SIP15 NSC
1 575 ₽
Описание: ИС, усилитель, DUAL 40 Вт, 4766, TO-220-15
data sheetСкачать Data Sheet
LM4766 OvertureTM Audio Power Amplifier Series Dual 40W Audio Power Amplifier with Mute
July 2003
General Description
The LM4766 is a stereo audio amplifier capable of delivering typically 40W per channel with the non-isolated "T" package and 30W per channel with the isolated "TF" package of continuous average output power into an 8 load with less than 0.1% (THD+N).
The performance of the LM4766, utilizing its Self Peak Instantaneous Temperature (°Ke) (SPiKeTM) Protection Circuitry, places it in a class above discrete and hybrid amplifiers by providing an inherently, dynamically protected Safe Operating Area (SOA). SPiKe Protection means that these parts are safeguarded at the output against overvoltage, undervoltage, overloads, including thermal runaway and instantaneous temperature peaks. Each amplifier within the LM4766 has an independent smooth transition fade-in/out mute that minimizes output
  • Количество каналов: 2
  • Output Power: 40 Вт
  • Диапазон напряжения питания: 20 В ... 60 В
  • THD + N: 0.1% @ 30 Вт, 8 Ом
  • Load Impedance: 8 Ом
  • Amplifier Case Style: TO-220
  • Количество выводов: 15
  • SVHC: No SVHC (15-Dec-2010)
  • Тип корпуса: TO-220
  • Amplifier Type: Power
  • Bandwidth: 8 МГц
  • Семейство: 4766
  • IC Generic Number: 4766
  • Input Offset Voltage Max: 10mV
  • Load Impedance Min: 8 Ом
  • Количество логических функций: 4766
  • Number of Amplifiers: 2
  • Рабочий диапазон температрур: -20°C ... +85°C
  • Operational Amplifier Features: аудио
  • Output Power Pout: 40 Вт @ 8 Ом
  • Power Rating RMS: 40 Вт
  • Slew Rate: 9
  • Supply Voltage + Nom: 30 В
На английском языке: Datasheet LM4766T - National Semiconductor IC, AMP, DUAL 40 W, 4766, TO-220-15
